diyAudio Sponsor
Old 29th May 2007, 02:07 AM   #1
eeyore is offline eeyore  Australia
Default Ponderings on hybrid 300B
Been reading through heaps of stuff on the net and on this forum, and I was pondering about the design and subsequent construction of a very high quality SET based on the 300B and 417A/5842. What I was wanting is to limit the use of transformers and chokes/inductors. On the two part reason to reduce cost and weight. So, here is something I have been thinking about:
- Regulated DC Heater supplies. Using 317T or similar.
- Regulated DC B+ supply (around 350~400V).
- Input stage (no volume control) 417A, with a CCS feed (ala Tubelab type design or the design from another thread ())CCS PCB Thread
Beyond this, I am unsure as to what would be a good design to complete the amp. Looking at the DRD, Angela, Audionote, Tubelab, Andrea Ciuffoli, parafeed, etc, etc, what are the various opinions?
Elements that I know are missing:
- Method of coupling between stages.
- Design of output stage.
- Further PS considerations.
If we take on the assumption that the speakers will be a reasonably high efficiency full range single driver around 90 dB+ and that the music will be a range of music, from classical to hard rock.
What are the missings parts of the puzzle? What are the various opinions and designs?
DF
http://diy-audio-blog.blogspot.com
Old 29th May 2007, 02:57 AM   #2
Some more thoughts...
How would the above kind of design make use of an ultrapath output stage?
The kinds of stage coupling? What are the benefits?
- CR
- Choke
- Transfomer
- Other?
DF
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
Fusion Hybrid 300B otto88 Tubes / Valves 5 24th October 2008 03:39 AM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
Zen V5 hybrid MIKET Pass Labs 5 1st August 2003 07:37 AM
Page generated in 0.06213 seconds (75.19% PHP - 24.81% MySQL) with 10 queries
