| diyAudio Sponsor | ||
Guys,
Maida Regulators are going to be needed here. Would somebody please recommend a replacement for the discontinued NSD134 NPN transistor. TIA.
Eli D. |
#2 |
TIP50
#3 |
TIP50 - good for 400V
For voltages above that you are getting into quite specialised and expensive stuff. Cheaper selections (if you can find them are below, note all these avail out of Farnell catalogue). 500V try BUL312FP 650V try BUL1403ED 700V try BU508D 800V try BUL216 Cheers, Ian |
#4 |
Or a high-voltage MOSFET...
Brian |
#5 |
Thanks guys. TIP50 it is. B+ in those old Fisher "boxes" is 110 V.
Eli D. |
#6 |
This may be a good place to use the TL783 3 pin regulator. It's a stand alone device good for up to 125v input-output differential. No pass transistor required.
Daniel |
#7 |
You don't need a pass transistor if and only if you can guarantee that the voltage differential will not exceed 125V at turn on or turn off. For a 150V supply, I'd be leery of that.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| Maida regulator | Andrewc556 | Tubes / Valves | 21 | 31st December 2010 03:29 AM |
| Using a Maida Regulator with a CCS | BL21DE3 | Tubes / Valves | 4 | 17th July 2008 04:42 PM |
| Maida regulator | billr | Tubes / Valves | 15 | 23rd September 2007 03:19 PM |
| Maida's regulator | mark_titano | Tubes / Valves | 3 | 29th January 2006 02:26 PM |
| Page generated in 0.07823 seconds (73.12% PHP - 26.88% MySQL) with 10 queries |
