diyAudio Sponsor
Old 11th February 2012, 01:49 AM   #1581
dvh99 is offline dvh99  Netherlands
Originally Posted by john29302 View Post
another flagship moskido up and running! awesome sound! played beatles revolver cd..the new stereo remix...awesome! got in claptons pilgrim cd...highly recommend it...just as you said it was. i can say its detailed and dynamic...mind you i only have mono...need some more parts...i am using the thailand 2sk1058/j162 pairs ...4 devices per side. the details are coming out i have never heard...the p's t's that make the microphone element bounce when the singer is singing, the cymbals brush...the little nuances here and there. just awesome detail and smoothness. my speaker is a 2 way cerwin vega 8 inch and its blowing me away. compared to modified st 70, stock mark 3 dynacos....well i will have to see but it appears it leaves them behind in its dust. transparent and detailed and the bass solid and not flabby as tube amps...well mostly so far incredible. usinf the vishay .33 uf orange drops. a little bright but hey...i am blown away. thanks and Godspeed.
congrats.
i am awaiting some paper in oil and some ft73 teflons to try as coupling caps.
maybe i`ll use some pio and ptfe in parallel and see what happens.
right now i have 1uf pp 600v epcos coupling caps.
every time i hear my moskido it amazes me, just like when i turn on my crt projector, just cannot get enough of its marvel.
beau, question about the russian 1578 and 1579 tubes.
is melz the only brand with those 1578 and 1579 named tubes?
Old 11th February 2012, 03:42 AM   #1582
john29302's Avatar
Default these authentic?
i was either to get some new tung sol or this tube. Anyone recognize these? says 80's military. but no way to tell if bona fide. i wonder if better than new tung sols?
1579 AUTHENTIC RUSSIAN / 6SL7 / 6N9S / 2 NEW NOS !!! | eBay
Old 11th February 2012, 05:11 AM   #1583
mr2racer's Avatar
Did you see these?
(5) 6SN7GTB Sylvania vacuum tubes NOS Tested OK | eBay
Old 11th February 2012, 06:56 AM   #1584
beau2317's Avatar
john : the ones you link to on ebay are the real thing. You are lucky to find them - snap them up at that price!
The 1578 / 6SN7 ones are much harder to find and many people are selling fakes. The two things to look for on these are (1) holes in the anode (2) the metal strengtheners that hold the innards still. See the 1579 example above to see what I mean. Here's some examples:
FAKE
These ones are interesting. They have the holes but not the proper metal supports. I think they are lesser tubes.
So, I can't see any real genuine 1578's right now on ebay. But they are not worth the money imho.
This is a real one - note also it has 1578 stamped on it..
Moskido (Hybrid Aikido/Mosfet); Verumecce (biased interconnects). Buffalo III with Unbalancer tube output; Magnepan 3.6R
Old 11th February 2012, 12:40 PM   #1585
mr2racer's Avatar
Guys,
How do these Russian tubes compare with NOS American made 6SN7's? I have 13 NOS tested matched 6SN7's. GE, Sylvania and RCA.
And thanks for the recommendation on the Mundorf's. I bought the Silver in oil caps. There is a huge improvement over the Solens! Now I just have to come up wth the money to put them in my power amps.
Old 11th February 2012, 02:28 PM   #1586
john29302's Avatar
cant really justify blowing money but...same guy had some 1578 fakes for cheap so i got 4 of those and 4 real 1579's or maybe i got burned. maybe they are close to the real ones. 6SN7 / 1578 / 6N8S / 6N8M RUSSIAN METAL BASE / 2 NEW NOS =1950= | eBay
Old 11th February 2012, 02:31 PM   #1587
thanks for the link john , i bought all 4 of them (2 for my aikido linestage and 2 for the moskido).
Old 11th February 2012, 02:32 PM   #1588
john29302's Avatar
oops...here is what i bought...they say it is close to the real thing
1578 / 6SN7 / TOP RUSSIAN 6N8S / 4 NEW NOS =1960s= | eBay
Old 11th February 2012, 11:27 PM   #1589
beau2317's Avatar
Well, before I built moskido I played with a lot of aikido preamps. I quickly discovered that octal tubes sounded better than 9-pins.
Then I started buying all sorts of NOS tubes. Spent a small fortune. Got a wide range, including some of the supposedly best (although not the 'legendary' types that sell for $400 each). Tung-Sol, RCA Red base, lots of sylvania, and so on.
Short story is that the Russian 1578/1579 ones trounce them all. They are cleaner, more musical. Just better. In those days (which is about 5 years ago) you could buy pairs of 1578 for $99. The guy selling then would only sell 2 per week, so you had to win auction after auction to collect enough. I wish I had bought more. I only got about 4 pairs.
On the other hand, the 1579s were common and cheap. I bought 20 for about $60. Again I wish I'd bought more. I've swapped several of these and don't have any left for sale, sorry.
Legend has it that these tubes were used in special projects like nuclear missile control (in the 50s, 60s) and they spared no expense getting them perfect.
As far as the majority of NOS tubes go, most are nothing special and the new production Tung-Sols are just as good, if not better.
Old 12th February 2012, 12:40 AM   #1590
mr2racer's Avatar
Thanks Beau, the only advatage to these tubes is that they were FREE! I intend to use them in an Acrosound amp, the Hafler and Keroes.
MOSKIDO - Hybrid Tube/MOSFET Amplifier Kashmire Pass Labs 7 22nd September 2011 08:30 PM
Page generated in 0.09611 seconds (69.16% PHP - 30.84% MySQL) with 11 queries
