| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#121 |
Tubee,
Can you tell me more about 'snubber' or draw a simple schma if possible. I'm a newbie and don't know much about that. Thanks Albert |
#122 | |
See the attached pic. |
#123 |
Hi, Albertli
The attachment didn't go thru, possible file size too big...I shall take a smaller pic ..... my apologies. JueiC |
#124 |
My Moskido..
The heatsink is bit too small..otherwise this is a good amp JueiC |
#125 |
jueic,
This is nice. How many pair of mosfet you have on? 2 pairs on each side? Albert |
#126 | |
Read on it : http://www.diyaudio.com/forums/showthread.php?s=&threadid=58461&perpage=25&pagenu mber=2 http://www.diyaudio.com/forums/showthread.php?threadid=3894&highlight=rectifier I added a 2.2K resistor over each powerrail(pos and neg each channel) Added a 1ohm with 100N MKT cap in series over each powerrail, this dampens HF from diode. Alternatively use Hexfreds, i suspect they don't need a snubber anymore.
Daisy Bell |
#127 | |
I only have 1 pair each side due to my earlier mistake of choosing small heatsinks. Your one have huge heatsinks, that is the proper way to run MOSFETs. I also found only the matched pair should be used.. mainly because of thermal balance is extremely important in MOSFET outputs. JueiC |
#128 |
Tubee,
Thanks for the reply, but that 2 sites cannot be reached Albert |
#129 |
Jueic,
I'm going to run 2 pairs each channel with the old Hitachi 2SK134 and 2SJ49. I have them sitting on the box for over 20 years. See how they would work for me. Albert |
#130 | |
http://www.diyaudio.com/forums/showt...888#post655888 The 2nd link was for a CDP's and contained non-working url's. Btw i added a 0.12ohm resistor after the hexfreds, i will remove them soon because bass has become more muddy and less controlled (the amp has a slightly higher internal resistance, also becaus i use only two fets/channel) I also swapped the standard diodebridge for hexfreds, maybe the hexfreds result in a somewhat higher resistance too? The powerfets give for me the most natural sound in mids and treble compared to bipolar transistor, but bass is outperformed bythe latter imo. Or put 8 fets or more parallel
Daisy Bell |
| MOSKIDO - Hybrid Tube/MOSFET Amplifier | Kashmire | Pass Labs | 7 | 22nd September 2011 08:30 PM |
| Page generated in 0.08947 seconds (69.00% PHP - 31.00% MySQL) with 11 queries |
