Old 28th May 2007, 07:11 AM   #1
Default Advice for retubing VTL Ichiban`s
Hi all of you.
I recently bought a pair of VTl Ichiban mono amps. These are 200W triode amps using 12! EL34 / KT90 /6550C pr. channel. I bought them as projects. They have not been used for several years and needs going over with new tubes, sockets ect. Bying 24 output tubes is quite an investment so I would like to get it right the first time. These amps are only operated in tiode mode and the current in each tube is quite modest. (about 25mA)
I am considering The EH KT90, the amps were sold with EI KT90 when new. What difference in sound should i expect from these compard to svetlana 6550C in the same circuit.
I neet a base that is as tight as posible as i am driving a pair of Quadral Titan MK III transmisionline speakers. For the rest of the fq. band i like "Telefunken " sound a lot. Anny input is welcome.
Thanks - Peter Jensen, Denmark.
Old 28th May 2007, 07:15 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
they are probably best sounding with KT90 ;
if you need replacement (test them!) your man is probably just Jim McShane
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Samadi Ichiban or Magic Cube by Dick Olsher dsrviola Multi-Way 2 21st May 2008 06:15 PM
Retubing my amp (EL84, ECC81, ECC83) - Tube recommendations? horace Tubes / Valves 18 18th December 2007 01:54 PM
Advice for retubing VTL Ichiban`s webercarbmann Tubes / Valves 4 4th June 2007 08:48 PM
DIY advice matt J Digital Source 5 2nd January 2007 07:11 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
