| diyAudio Sponsor | ||
Hey all,
I have just read thru the following post of the Musical Fidelity X10D Pre/Tube Buffer MF XPre troubleshooting It looks interesting that its on a +/- 30VDC supply (and 6.2VAC Heaters) Anyway, I was thinking of building one and have a newbee question: For the +/-30VDC, I have a 21 - 0 - 21 Toroid that I was thinking of using with a Full Bridge Rectifier/10,000uf smoothing caps to get +/-30V rails. For the Heater Voltages, I was planning on winding a new coil onto the 21-0-21 toroid to get the required 6.2VAC for the heaters (AC on heaters) Any thoughts/comments on whether this is a good idea? The rest of the components look like they should be to difficult to get...my first tube pre, hence the lame-o question... Thanks |
#2 |
Hi John,
I have owned one of these and IMO they are very ordinary. There are better projects out there |
#3 |
Thanks for the heads up...
But the concept of using a 21-0-21 80VA toroid is possible? Do you know of another lower voltage (30 ish) simple tube preamp designs out there? Again, I want to build it, not buy it. |
#4 |
There is a low voltage version of the Aikido which uses ECC86's (a tube designed for low voltages - as opposed to the ECC88 which isn't).
I had a X10D and I liked it when I had medioca gear. The thing that I found was that it seemed to be optimised for the supplied tubes. I tried other tubes and didn't like the result. I agree - you can do a lot better. Shoog |
| Page generated in 0.07034 seconds (72.71% PHP - 27.29% MySQL) with 9 queries |
