| diyAudio Sponsor | ||
Just picked up a pair of tube monoblock amplifiers - Quicksilver KT88s - one is dead quiet, the other has a rather loud mechanical hum. The output signal - through the speakers - is fine. This is a hum at the amp itself, so I assume it's power transfomer related. I can't feel any vibration - the mounting screws are tight - any ideas? Regards, Bill.
#2 |
Failing power relais (if it has one) or bad transformer. If the latter there are ways to reimpregnate them using diy stuff
Sometimes bad rectifier tubes can cause noise too.. |
#3 |
One of my amps does that. I think because do to the nature of the design I had to half wave rectify it which causes an asymetrical flux swing. This is probably not the case for you though, but I know how annoying it is. I've considered filling the transformer end bells with epoxy to dampen it. Or making a dummy load to load the negative half cycle, but this option is a waste of energy and my inner tree hugger won't let me do it.
#4 |
Thanks! Bill.
#5 |
My first comment ay DIY audio... I thought maybe I could help you out, since I had a mechanical hum on my PS Xformers as well. What finaly cleaned it up was to install a ' DC blocker circuit ' on the 120V primaries.
Looks like this... (thanks Yeo @ diyparadise.com) |
| Philips Cdm’s mechanical alignment | Scorpio(DDMF)! | Digital Source | 6 | 9th October 2007 03:58 PM |
| CDM-PRO2 Mechanical Kit | HpW | Digital Source | 0 | 17th June 2006 03:23 PM |
| Mechanical ear | purplepeople | Everything Else | 1 | 5th February 2005 02:40 PM |
| New forum/-Mechanical | Magura | Everything Else | 0 | 29th March 2004 01:21 AM |
| Mechanical Gears, where to buy cheap? | lgreen | Parts | 7 | 17th May 2003 04:37 AM |
| Page generated in 0.07448 seconds (71.06% PHP - 28.94% MySQL) with 11 queries |
