Question about biasing heater above cathode in a direct coupled circuit.
Old 26th May 2007, 07:27 AM   #1
G is offline G  United States
G's Avatar
Default Question about biasing heater above cathode in a direct coupled circuit.
Hi all. I have a direct coupled version of a 12B4A amplifier that I would like to build. The cathode of the output tube(12B4A) is sitting at 174v above ground. The input tube has the cathode sitting at 6v above ground. I would like to bias the heater of the input tube above the cathode to cut down on hum. Since the cathode of the ouput tube is so far above the heater relative to ground do I need to worry about it producing hum? I suppose I could just use DC on the heaters but I would prefer not to. I think biasing the heaters up to around 50v will be ok but I would like some opinions. Thanks.
Gavin
Old 26th May 2007, 11:42 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The ideal is to make the heater 40V positive with respect to the cathode. You need two heater supplies; AC will be fine so long as you do it properly. You definitely need to bias the 12B4A heater to > +174V, otherwise you will get noise (even on an insensitive stage) and possibly eventual heater/cathode insulation breakdown.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Question about biasing heater above cathode in a direct coupled circuit.Hide this!Advertise here!
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 84 17th April 2017 07:40 PM
cathode biasing question puginfo Tubes / Valves 7 3rd June 2009 03:24 PM
newbie asks question :cathode biasing garbage Tubes / Valves 9 17th April 2007 09:20 AM
6DJ8 cathode heater voltage question. Morse Tubes / Valves 13 30th January 2003 07:59 PM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
Copyright ©1999-2017 diyAudio
