| diyAudio Sponsor | ||
Hi all,
I've just purchased a batch of NOS tubes in Israel. I got EL84, ECC88/6DJ8 , 5U4GB, 5R4GYB, 6080WA (RCA) and 6AK5 (RCA). The question is what can I do with the 6080WA and the 6AK5 . I bought them on a hunch at about $4 a piece. Avi |
#2 |
6080 can be used in pushpull triode outputs, otl amplifiers, and as a series pass element in a tube based voltage regulator it is basically the same as a 6AS7..
http://www.mif.pg.gda.pl/homepages/f...137/6/6AK5.pdf Should be good as a ccs, a pentode based voltage amplifier and probably works ok in triode connection as well.
www.kta-hifi.net |
#3 |
Thanks, this will help me.
Avi |
#4 |
6080's also work rather well in PP amps with output transformers. Married to the 6H30's they can make a very nice 3 valve stereo amp.
Shoog |
#5 |
Thanks. There's not much literature about the 6080WA. I wonder if you know of any amp schematics. Thanks Avi N2EGL |
#6 |
The 6080 can be used exactly like a 6AS7 so just look for 6AS7 amp schematics, there should be some floating about. |
#7 |
Lots of people use the 6080 as a cathode follower to drive high impedance headphones. I tried it as a line stage and could never get it quiet enough.
http://www.ecpaudio.com |
#8 | |
Kevin, The data sheet suggests the 6AK5 is a linear high RF type. It should be reasonably low noise to do that job. Do think a 6AK5 with regulated B+ on both plate and screen would make a good 2nd gain block in a phono preamp? Gm is 5 mA./V. So, approx. 35 dB. of gain is produced with a 12 KOhm load resistor. FWIW, my thinking is a 6922 section for the 1st gain block, a 6AK5 as the 2nd gain block, and a DC coupled cathode follower to buffer the O/P.
Eli D. |
#9 |
Hi Eli,
Seems worth a try..
www.kta-hifi.net |
| Schematics & Info on CAL SC-Ten Tube DAC? | perfusionist | Digital Source | 2 | 16th January 2010 09:03 PM |
| Tube info needed | Marik | Tubes / Valves | 0 | 13th February 2008 06:11 AM |
| Need info on RCA 813 used in Tube Amp | Amp_Nut | Tubes / Valves | 4 | 10th December 2006 12:45 AM |
| info needed on the 7c6 tube | karma | Tubes / Valves | 2 | 13th August 2005 08:33 PM |
| Need info about 5G84 tube | reaction | Tubes / Valves | 3 | 13th January 2005 08:34 AM |
| Page generated in 0.09093 seconds (82.96% PHP - 17.04% MySQL) with 10 queries |
