help needed with noise in phono preamp - Page 2 - diyAudio
Old 27th May 2007, 09:12 AM   #11
Default and another one
Heres another. The phono section is to the top. the fist uppermost socket is the 6sl7 with the lower of the 2 the 6sn7
Further below that is the 6sn7 in srpp topology.
This is my second amp ever, so please excuse any mortal sins i may have committed The power supply is a variation on the following.. I supply a link so as not to infringe copywrite issues. With all credit to the original authors for the work.
http://eshop.diyclub.biz/article_info.php?articles_id=3
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 27th May 2007, 11:16 AM   #12
On Hiatus
SY's Avatar
Top view?
IIRC, this is the schematic:
http://www.hagtech.com/images/cornet2schem.gif
Is that correct?
And the red and white wires that are bundled together, are those power distribution? Where are the input signal leads for the phono?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th May 2007, 02:29 PM   #13
Default Wires
Hi
Yes the schematic is the one you have listed.
The red and white wires are input signals. the selector switch is inbetween the middle valves.
Power distribution is either side.. in the larger picture you will see red and grey wires coming form the back panel.
I have given you a top shot
Thanks for your help
Old 27th May 2007, 02:30 PM   #14
Default And the PSU
heres the psu
Old 27th May 2007, 02:31 PM   #15
Default I could have cleaned the dust off them
They were clean 2 days ago!!
Heres both together
Old 27th May 2007, 02:34 PM   #16
Default input into phono
You can see a short white wire near the 47k resistor on the right side of the close up photo --- to the left of the bundle of red/grey wires in top right corner of photo
Nick
Old 27th May 2007, 05:36 PM   #17
dvisves is offline dvisves  United States
Hai duderduderini
With such a lot of wiring it is really impossible to control feedback and hum.You are much better getting a pc board made.I can help if you send me the schematic and design a simple pc board
DeeVee
deevee
Old 28th May 2007, 04:23 AM   #18
Default Thanks
Hi.
I really appreciate that very kind offer. I would consider it but that would be contingent to Jim (the owner of the circuit being cool with it).
I am thinking maybee i can reduce it by trying a few things and failing that maybee some form of noise cancelling circuit, the likes of which i have seen on tubecad.com.
So I will take a raincheck on your very generous offer but if i cant reduce the hum and more importantly Jim Hagermann says its ok then I will contact you
Nick
Old 28th May 2007, 04:39 AM   #19
Default To Sy its the comet or cornet OCTAL not the image you posted
HI
I just realised its not the schematic you posted.. its the OCTAL version
Nick
Old 28th May 2007, 03:26 PM   #20
On Hiatus
SY's Avatar
If you can find a link to the octal version, post the link here. In any case, I'd look at the order of the grounds. From your photo, it appears that you have a star ground in the middle of the row of input jacks, with the phono grounds separated from the star point and a few other grounds tacked in between. The grounds from the phono input and the first stage grounds (i.e., the cathode and grid leak resistors) should return directly to the star point without any other grounds in that path. Return any other grounds to that point using separate wires.
Noise on the RIAA phono preAmp diarav Chip Amps 3 23rd March 2007 05:27 AM
Phono Preamp Design Needed AudioFox Tubes / Valves 9 15th June 2006 08:11 PM
Super fast, low noise phono preamp dioklecijan Analogue Source 30 19th July 2004 09:52 PM
Capacitors for phono preamp needed maestro00 Parts 2 25th June 2004 01:49 AM
Copyright 1999-2017 diyAudio
