| diyAudio Sponsor | ||
Hello to all
I have a question about Interstage Transformers with pentode drivers in a SE amp. Why havent I seen any such amps? What's the reason for this? Are there any reasons for why not? Looking forward to more info on this. Best Regards
Yoda: "May the Force be with You" Acoustic design: www.fmdesign.com Check out the Griffin loudspeakers! |
#2 |
In the Bouyer ST150 amplifier (1966 made) two 6L6 in pentode configuration drives 4 6L6 in class-B2 using an interstage transformer... (with NFB form secondary of the interstage transformer)
Andreas |
#3 |
We91,
The lack of SE IT's in general and pentode SE IT's in particular has to do with how difficult it is to get them to work. There is no such thing as a generic SE IT for pentodes. Each would have to be made for a specific driver tube, run under a specific set of conditions. Then would come all of the cut and try and measuring because the math just falls apart when you get to this level of complexity. If you are willing to spend the money, and it will run to several hundred dollars, you might interest a custom house in attempting it. But, there would be no guarantee you would get what you thought you paid for and that it would work as you wanted. Spend your money on a really good coupling cap. Bud |
#4 | |
There are some topologies that add lots of local NFB in order to reduce the otherwise unacceptable pentode plate resistance. However, I haven't seen that done in anything other than AM modulators where fidelity isn't a concern. |
#5 |
Thank you very much, guys!
In almost no time at all, my question was answered. Have a nice weekend! Best Regards Aril
| pentode aikido driver for 300b | dave dove | Tubes / Valves | 18 | 24th March 2012 08:37 PM |
| Simple Pentode driver for a 45 ? | Steven-H | Tubes / Valves | 1 | 11th January 2009 11:39 PM |
| Pentode Driver Calculations | dsavitsk | Tubes / Valves | 19 | 20th December 2008 12:24 AM |
| E80L pentode mode as driver? | pmillett | Tubes / Valves | 1 | 3rd April 2008 08:49 PM |
| Help with a cathode coupled pentode driver? | Svetlana | Tubes / Valves | 2 | 26th July 2006 01:06 PM |
| Page generated in 0.06658 seconds (83.69% PHP - 16.31% MySQL) with 10 queries |
