| diyAudio Sponsor | ||
Hello,
Sorry to stress you guys again with my strange questions, bud does anyone knows a suitable operating point for a g2 driven EL81 push-pull? I am thinking to build the preamp section following the Berning EA230 schematic.... The problem, as usual, is the required plate to plate load for the 2 EL81, the negative g1 voltage and the b+ voltage to the plates Thanks again Giulio Maiocco |
#2 |
This is not a simple problem as it is possible to find many operating points given the variety of possible combinations of -Vg1 and Vg2. In theory, an extensive drawing of curves for variuos -Vg1 could give you a sweet-spot.
Another approach would be to make an educated guess. Have a look at the datasheet at: http://www.mif.pg.gda.pl/homepages/f...030/p/PL81.pdf Speciffically page 6 (class B PP operating point example) and page 12 (G2 curves for Vg1 = -1V). As you will see, the Vg2 curves are similar to pentode curves so the pentode class B operating point could be used, perhaps with a higher V plate and higher P-P load. For lower Vg1 the required Vg2 will be lower, ditto Vg1, but the linearity might be worse. |
#3 |
Hello,
This probably will show that I'm completely ignorant when it comes the need to use the tube curves, but could what I "drawn" possibly work without melting the E/PL81? I have quite a lot of them, but I'm always disappointed when I have to junk tubes! Also, plese could some kind soul explain me how to calculate the optimum plate to plate load starting from the curves of the tube? Please, no difficult math, as I have a hard time figuring how it works! Regards Giulio Maiocco |
#4 |
Look on Patrick Turner's webpages.
http://www.turneraudio.com.au/ Click on the Educational and DIY page. All you ever wanted to know about load matching. Cheers, Ian |
#5 | |
And what gingertube says.
Ears aren't microphones. |
#6 |
Hello,
Thanks a lot for the link about the plate to plate load calculations, I have to read it again and "experiment", as for now it is still a bit fuzzy. Anyway, I tried to do the "plot" for the EL81 and it seems it is not one of the best tubes to be used in audio applications, mainly because of the very low anode dissipation! I traced the plate dissipation on the graph, it is hand- drawn, so not much precision! Is this time the "plot" right or should I correct something else? Cheers Giulio Maiocco |
| Calculating operating point of a DHT | Pyre | Tubes / Valves | 2 | 26th February 2009 10:09 PM |
| Operating point for 6GK5 | AKSA | Tubes / Valves | 6 | 6th October 2008 03:21 PM |
| SE amp: Please suggest a better operating point | zobsky | Tubes / Valves | 34 | 21st September 2008 12:00 AM |
| Best Operating point for a 2A3? | sgerus | Tubes / Valves | 10 | 2nd August 2006 12:31 AM |
| 6GM8 Operating Point | ALBQ | Tubes / Valves | 2 | 23rd November 2004 02:45 AM |
| Page generated in 0.08908 seconds (78.28% PHP - 21.72% MySQL) with 11 queries |
