| diyAudio Sponsor | ||
Hello
Many thanks to those who helped on my previous question. Can anyone give me gneral guidance or direct me to a site that discusses replacing the single cathode resistor in a push pull out stage with separate ones and perhaps making them variable to match up as close as possible two unmatched output tubes. I have both a heathkit and dynaco that are like that. thank you much oldheathkitphil
oldheathkitphil |
#2 |
Through some searching, I've found this thread which seems to discuss the topic to my satisfaction. Pay particular attention to the first dozen posts or so, after that it tends to wander off topic. Also remember the cathode bypass caps are essential to the circuit with separate cathode resistors, otherwise you are seriously screwing with the AC impedance of the outputs.
bias arrangements for P-P amps. You might take a look at http://www.diytube.com/phpBB2/viewforum.php?f=1. They have an entire forum dedicated to a "build your own" Dynaco ST35 clone. One significant modification to the original Dynaco circuit is the replacement of the common cathode resistor with separate adjustable circuits. I think that is exactly what you are seeking. |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| 6T9 push pull with Cathode Coupled input | Brit01 | Tubes / Valves | 5 | 18th January 2009 11:58 AM |
| LED cathode biasing in push-pull input stage | exeric | Tubes / Valves | 14 | 18th August 2008 01:35 AM |
| Push-Pull Cathode Bias Resistors | Kashmire | Tubes / Valves | 5 | 6th January 2008 07:38 PM |
| The cathode FeedBack in Push-Pull amp | jmartins | Tubes / Valves | 3 | 13th May 2005 03:17 PM |
| Page generated in 0.06282 seconds (69.88% PHP - 30.12% MySQL) with 10 queries |
