#21 |
Thanks, got it!
I have stash of C3m and C3o tubes to experiment with during the summer.
Thanx! |
#22 |
I have a couple of questions re. triode-connected C3m if anyone could help... 1] Triode-coupled, what's the approx. amplifcation factor? 2] How do they sound? Specifically, compared to the Russian 6c45 or similar? Many thanks! Doc |
#23 | |
Depends of the circuit..., µ g1/g2 = 19. Andreas |
#24 |
AndreasS, hope you will take a minute to answer a simple question since you obviously know this tube well:
Is the Ri in triode mode around 2k?
Thanx! |
#25 |
The Ri (triode mode) is shown on datasheet page 17
http://frank.pocnet.net/sheets/009/c/C3m.pdf For the operation point @ 16 mA Ri is around 2,5 kOhms Andreas |
#26 | |
Thanks Andreas |
#27 | |
Thanx! |
#28 |
bequerel,
to determine the plate resistance of any tube at any operating point, plot the operarating point on the plate curves, then draw a line tangential to the curve that runs through your operating point. The slope of that line (delta V over delta I) is the plate resistance. Easy !
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#29 | |
Thanx! |
#30 |
i would like to build one myself. have the siemens tubes in my drawer.
got any schematic to share? TIA erwin |
| C3M linestage | costa23 | Tubes / Valves | 15 | 23rd August 2009 08:53 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| My 6S19P Linestage | sorenj07 | Tubes / Valves | 4 | 12th April 2008 06:21 PM |
| An almost DIY 6DJ8 Linestage | JesseG | Tubes / Valves | 37 | 17th November 2007 11:43 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
