C3m linestage - Page 2 - diyAudio
Old 23rd May 2007, 06:23 PM   #11
Originally posted by kstagger
I have Philips, Haltron, Valvo, Siemens and Lorenz C3ms...
The C3m was made by Philips (Valvo), TFK, Siemens and Lorenz; Haltron is only a rebrander
... TFK was had a solid-mesh - interesting. Some of the older EF40s used a solid-mesh and it's also used with some EF86 tubes....
This mesh in the C3m, EF40, EF86, EF806 is the sreen, the anod is solid (analoque 6C6).
Regards Andreas
Old 23rd May 2007, 07:02 PM   #12
kstagger's Avatar
Originally posted by bequerel
Great looking preamp, kstagger!
Nice to see projects where the constructors have made an effort to make their projects look good, too.
thanks - I made that preamp to be used for a long long time so I could concentrate on other parts of my stereo. So far I've been very pleased with the sound - but I may be going back to a triode connected EF86 for my next linestage project.
Old 23rd May 2007, 10:04 PM   #13
coresta is offline coresta  France
coresta's Avatar
and the same plants for C3g ...
AndreasS Pierre
Old 23rd May 2007, 10:11 PM   #14
Account Disabled
kstagger,
nice looking preamp! How did you write the letters on the top?
Are they engraved?
Old 24th May 2007, 01:31 AM   #15
kstagger's Avatar
Originally posted by resident
kstagger,
Are they engraved?
thanks - it's all done via Front Panel Express
http://www.frontpanelexpress.com/
the software is easy to use once you get the hang of it...
Old 24th May 2007, 09:48 AM   #16
Account Disabled
Thanks! I'll ask them if they send to Europe too.
Otherwise, does anybody know an European manufacturer?
Old 24th May 2007, 10:52 AM   #17
...Otherwise, does anybody know an European manufacturer?
Yes, pls. ask Schaeffer, Berlin
http://www.schaeffer-apparatebau.de
Regards Andreas
Old 24th May 2007, 11:26 AM   #18
Account Disabled
thanks!
Old 4th June 2007, 11:29 AM   #19
kstagger, if you are still with us on this thread:
Did you "lift" the heaters up by means of a voltage divider, let them float or did you ground them?
The anode voltage is relatively high, so I would suppose that you exceed the maximum cathode to filament voltage differential if you did not "lift" the heater supply?
Thanx!
Old 4th June 2007, 12:55 PM   #20
kstagger's Avatar
I just used a diode bridge into a capacitor, followed by a 7820 3-pin regulator and some more capacitance. Grounded filament on one side. I probably could have gotten away with AC... but didn't have a suitable transformer on hand.
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 09:53 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 06:57 PM
My 6S19P Linestage sorenj07 Tubes / Valves 4 12th April 2008 07:21 PM
An almost DIY 6DJ8 Linestage JesseG Tubes / Valves 37 18th November 2007 12:43 AM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 06:34 PM
Copyright 1999-2017 diyAudio
