6V6 line preamp
6V6 line preamp
Old 27th June 2012, 07:59 PM   #981
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
6V6 line preamp
agree - better idea
smoke whatever you find
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th June 2012, 08:04 PM   #982
cjkpkg is offline cjkpkg  United States
well..I do have a toroid that I can use...
AS1T230
Electrical Characteristics
Outputs 4x
Power 100VA
Output Voltage Current
230V 0.22A
230V 0.22A
6.3V 3A
6.3V 3A
Keeping the choke load and dropping the resistors to 560 looks like I can still get there right?
Old 27th June 2012, 08:11 PM   #983
Zen Mod's Avatar
6V6 line preamp
gimme ziped sim file , write down DC resistances of all windings
I believe no one
do that , or Stajo will weld ya
Old 27th June 2012, 08:12 PM   #984
stajo is offline stajo  Sweden
6V6 line preamp
Thats more like it.
Old 27th June 2012, 08:22 PM   #985
6V6 line preamp
I've got a 3,5 kVA 230-24 in the closit. If i rectify that i can prolly weld railways for you
Old 27th June 2012, 08:51 PM   #986
I will measure resistance of the windings when I get home in a while...
File Type: zip cjk6v6toroid.zip (271 Bytes, 29 views)
Old 27th June 2012, 09:21 PM   #987
6V6 line preamp
http://www.antekinc.com/pdf/AS-1T230.pdf
Id say its in the region of 37 ohm if you use specs under load and let PSUDII count backwards by pressing the [...] button on the trannys properties.
Weldmeister
Old 27th June 2012, 09:38 PM   #988
6V6 line preamp
Old 27th June 2012, 09:42 PM   #989
Zen Mod's Avatar
6V6 line preamp
perookinfect!
47uF after choke means that rectifier isn't jeopardized with induced peaks .......
this solution can be almost on par with best solution - choke input filter+shunt reg , but we are here slightly short in voltage for that ....
Old 27th June 2012, 09:53 PM   #990
6V6 line preamp
perookinfect!
halfen R1 and you've got 20-25 V to shunt, but I dont think it will be audible. Just over a mV already...
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
