6V6 line preamp
6V6 line preamp
Old 25th June 2012, 11:51 AM   #921
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Its probably layout or error. I never ceased to be amazed how often i miss something simple. Check every component and node. Draw it on paper as you follow it over the board. You might be surprised. I doubt a beoskie psu is noisy. Could be wrong. Fwiw, i found i was using a really noisy transformer for my filament voltage. I think it was having trouble with the current draw. Cheapo Radio Shack.
...Shape the sound , Man!
Old 25th June 2012, 11:54 AM   #922
cjkpkg is offline cjkpkg  United States
The toroid I have has a 3 or 4 A 6.3V winding so I would prefer to use that...it will still give me a B+ of just north of 300 - about 315 regulated.
Old 25th June 2012, 12:19 PM   #923
stajo is offline stajo  Sweden
6V6 line preamp
What does the hum sound like, is it 100 Hz?
Old 25th June 2012, 12:58 PM   #924
I do not have a scope but it sounds to me a little higher pitched than 60HZ hum...so I guess it could be 100hz...
and it is very loud...
Old 25th June 2012, 01:28 PM   #925
6V6 line preamp
Rectified 60 Hz AC gives 120 Hz. Try measure AC with a DMM on your B+. If it shows above or anywhere near 1 volt you have a PSU problem. Should be a few millivolts. If its on the millivolt level, go search on the amplifier card.
Staffan
Old 25th June 2012, 01:46 PM   #926
here is a question...both PSU's I was using reference the heaters to B+/4. I see the schematic does not show this.
Any thoughts on this as a possibility?
Old 25th June 2012, 01:56 PM   #927
6V6 line preamp
Does that mean that heaters are lifted to about 70 v above ground? 6V6 should cope with that. Is it DC or AC on heaters?
I think I see that what looks like your cathode bypass caps is very close to the tubes. They get hot wich can affect their condition and reflect back on the tubes if they become unstable. I would keep caps futher away from hot tubes.
Staffan
Old 25th June 2012, 02:02 PM   #928
buzzforb's Avatar
Question. Have youused these psu boards before and did you have a noise problem then?
Old 25th June 2012, 02:51 PM   #929
The PS-1 I am using is also the same board I am using on a phono preamp. VERY quiet.
heaters are regulated DC
I was actually thinking about swapping this PS-1 to my tetra sans and see if it is quiet over there and vice versa.
Old 25th June 2012, 03:00 PM   #930
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
That one is almost like a Mosfet Maida. If there is a psu line problem it could be bad interaction not inherent.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
