6V6 line preamp
6V6 line preamp
Old 21st June 2012, 03:21 PM   #901
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Originally Posted by cjkpkg View Post
So, I am thinking I need to have all my signal wiring as per "normal" signal to signal and ground to ground and switch my speaker outputs on the power amp?
Don't ground your signal. Polarity reversal in SE is done on the speakers inputs which are floating devices.
Old 21st June 2012, 03:27 PM   #902
cjkpkg is offline cjkpkg  United States
gotcha...I recieved my regulated PSU yesterday too so I will try and stuff that tonight as well and get everything sorted out tonight maybe.
Old 22nd June 2012, 02:15 AM   #903
well...no dice yet...
hooked it back up with signal to signal and rca ground to rca ground and nothing but terrible loud hummmm...switching speaker outputs made no difference.
I am thinking now that maybe my pot is not hooked up correctly...
What are your successful wiring schemes for your input to pot to board to output wiring schemes?
I have an alps blue dual pot.
I went RCA ground to pot ground. then ran another wire from pot ground to board ground input. Could this be causing my ground loop?
Old 22nd June 2012, 02:22 AM   #904
Salas's Avatar
6V6 line preamp
Wiring a Pot
Old 22nd June 2012, 02:25 AM   #905
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Pictures are worth a thousand words Step away, play a game of chess or listento music, then recheck wiring. After pi cof course. If these guys got me up and running, i am sure they can help.
...Shape the sound , Man!
Old 22nd June 2012, 07:32 AM   #906
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Just a suggestion - do you have three or four pin Alps pot?
The four pin:
On the back it says:
Alps Japan RH2701 50KAX2
with terimals are
#1 Ground
#2 Out to amp board
#3 In from sel
#4 NC or Loudness
So if you have it on 4 you will get hum (open connection)
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anza´ Za´ka; --> FE103 sigma TQWT
Old 22nd June 2012, 12:50 PM   #907
OK, well that is how I have it...
RCA input Earth to pot, then from the pot earth connection to the board input ground.
Question though...where should the RCA output ground originate? The way mine is set up it ends up being the same point as where the input ground originates. I started thinking that this may be causing the loop.
It is a 3 pin pot and I have three others to reference so I am sure I am OK there.
I still suspect that it has to do with the output RCA's and the grounding scheme.
Old 22nd June 2012, 01:00 PM   #908
Salas's Avatar
6V6 line preamp
Star earth signal gnd everything to the cathode resistor's ground point to have a visually clean earth reference node, could be one idea.
Old 23rd June 2012, 12:19 PM   #909
OK, one more update.
I am using Broskies PS-1 for the PSU which has regulated B+ and heater supply. I originally had the heaters set up for series but last night I changed them to parallel.
I ran the RCA ouput ground to the ground on my PCB and the RCA output signal to the signal output and nothing but terrible hummm.
THEN I swapped ouput wires, PCB ground to RCA signal output and PCB signal output to RCA ground and IT MADE LOVELY MUSIC...for about 40 seconds...then the terrible hummm returned. UGHHH!!!!
This one is really stumping me...
Old 23rd June 2012, 12:34 PM   #910
buzzforb's Avatar
post pics of your amp. It may be a routing/wiring issue. Show the whole amp with pics of each compartment/section. May be good idea to look at your amp and draw diagram/ schematic. Sometimes in drawing it yourself, you can see where you made an error.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
