#891 | |
Wot... cpb? jumpyer?
weekend .... you ?well , but is ![]() ![]() ![]() ![]() Quote:
jaap Last edited by disco; 15th June 2012 at 07:51 PM. |
#892 |
Bypass, like our sooner doom
now i have to score two goals if you excuse me. Later on we'll speak ctbp. Zlatan
#893 |
Been lurking here for a while...I think I will whack up this linestage on a DIY PCB. I have a regulated B+ and heater supply that will work nicely.
Thoughts on the layout? I didnt label anything but it is a pretty simple design. Only thing I am struggling with is the input ground on the "right hand" side. I would P2P it but my chassis layout sort of demands as low a profile as possible. EDIT I plan to use a regulated 12.6V heater supply so 6V6's wired in series. Is this thinking OK? Supply is good for 2A. Last edited by cjkpkg; 16th June 2012 at 02:31 AM. |
#894 | |
Edit And I would make a star-grounding b4 putting everything to chassie if I were you, looking at the pic. Last edited by stajo; 16th June 2012 at 06:54 AM. Reason: Forgot |
#895 |
#896 | |
For the voltage regulator a PCB might save you some space but again it's good practice to have this few parts hard wired to the reg on a sink. When heating 6V6 in series, be sure to use the 'GT' version as they have a fixed warm up period. Older types don't so you'll possibly ruin the heater. From a developper's view not so safe idea in my opinion. Football? Tennis you mean
jaap |
#897 |
Dude I hardwired 2 SSHV2 on a cooler. I think it was somewhere there I had to consult my shrink. I recommend everyone to start discoing here. That means skip regs, build a proper c-r-c and listen. Then add **** and listen
Tennis is my life Last edited by stajo; 16th June 2012 at 07:29 AM. |
#898 | |
If I put the RCA cable signal (center pin) on the ground part of the RCA output(outer ring) then I get a clean, quiet signal with no gain but it is very quiet. So, I am thinking I need to have all my signal wiring as per "normal" signal to signal and ground to ground and switch my speaker outputs on the power amp? |
#899 |
Also, heater voltages in line, B+ of 315v, and 14V on the cathodes. Otherwise built exactly per the original schematic.
#900 | |
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
