Old 14th June 2012, 07:43 PM   #871
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Zen Mod View Post
not me , Bubba
I'm just ZM
Zodiac Master valve psychologist then.
Old 14th June 2012, 07:44 PM   #872
disco is offline disco  Netherlands
disco's Avatar
Anyway, I took some actual measurements (in which I'm certainly not an expert). In my setup the pre is driving a 27 triode, having a grid to cathode capacitance of 3.1 pF. As a load I paralleled a 10K ohm resisor and a 3.3pF capacitor.
In the first setup (with cathode bypass) a 1KHz square wave of 200mV rms gave an output of 990mV rms (5 times amplification). In the second setup (without cathode bypass) a 1 KHz square wave of 200mV rms gave 460mV rms output (2.3 times amplification).
Here you'll find some results. Voltages are derived from a Fluke 87 true RMS multi meter. Don't know what frequency domain it can handle.
jaap
Old 14th June 2012, 07:46 PM   #873
buzzforb's Avatar
I picture him as being like the guy in white coat who use to give me electroshock when i starting talking to my special friends.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 14th June 2012, 07:50 PM   #874
Salas's Avatar
You lost half your gain without the cathode cap, expected. Don't load it under 20K btw, it has about 1.5K Zo in common cathode and bypass mode for instance.
Old 15th June 2012, 09:47 AM   #875
triode_al's Avatar
Agree. I had 3k9 on my R120 and EL34-triode at 240V. The amplification was low of course, and the sound was very 'warm' - second harmonics. But I drove a Hitachi FET output directly with it and that worked like a charm. At the end I thought it too - well - vague.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Old 15th June 2012, 10:25 AM   #876
buzzforb's Avatar
Ran my PSU setup in PSUD last night. According to it, should be ideal. Guess that means i will spend this weekend scoping and rewiring PSU. Salas, ZM, what is your impression, if any, about high quality cap like PEH169 in prefilter vs motor run cap? Got my order queued up, and can add peh or bhc to the list. Not sure if it is woth the coin for an electrolytic, that in theory at least, should not be as good as film/motor run cap.
Old 15th June 2012, 10:44 AM   #877
stajo is offline stajo  Sweden
Try PEG124, 33 or 47 uF on second C in filter and parallell up to a value where it gets silent with the ear in the cone. No need to go as big as PEH169 HV stuff for a start. IMHO.
Staffan
Old 15th June 2012, 10:47 AM   #878
buzzforb's Avatar
more a question of sound difference, if any. I am audiophool trying to learn secrets of audiophoolery
Old 15th June 2012, 10:59 AM   #879
That might be a bit application dependent but my last little EL84-amp ended up with a combination in second C. 50 uF motorrun and 100-ish PEG124. To much plastic narrowed the sound to my ears. I actually prefer good electrolytics to plastic as base.
Do some listening tests, its fun and it might surprice you.
Staffan
Old 15th June 2012, 11:52 AM   #880
buzzforb's Avatar
Exactly what i was looking for. THnaks
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
