6V6 line preamp - Page 83 - diyAudio
Old 11th June 2012, 08:09 PM   #821
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Bas Horneman View Post
I'll try Salas's suggestion first. Replace grid stopper carbon film with metal film.
Just in case it really is coming from the line stage. Better secure that fact first. But a Dale was more transparent anyway.
Old 11th June 2012, 08:13 PM   #822
Salas's Avatar
I'll try without
Check for ringing on 10kHz squarewaves if without a stopper. It does work with clean rising edge sans stopper sometimes depending on wiring, pot, etc.
Old 11th June 2012, 08:25 PM   #823
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Visaton B200 open baffle .
Old 11th June 2012, 08:31 PM   #824
Salas's Avatar
So not especially prone to highlight hiss though sensitive enough. If its the source and the gain surfacing it, and because you had been listening with no line gain before, its not a bad idea to check the system with the bootstrap buffer option too before you settle. Just a rewiring, not major.
Old 11th June 2012, 08:41 PM   #825
disco is offline disco  Netherlands
disco's Avatar
Originally Posted by Salas View Post
Hey! Long time no see Mr. Jaap.
It's been too long
Came back for a taste of your 6V6 pre.
Got one in the oven right now, very basic to begin with.
I noticed the Simplistic HV has a version two, suited for higher voltages.
Must locate the parts to build one. Lots of smoke hanging in the air in that tread
jaap
Old 11th June 2012, 09:08 PM   #826
Salas's Avatar
Old 11th June 2012, 09:13 PM   #827
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Bas, you built 2 separate power supplies, one for each channel?
Was there any noticable difference than one ps for both channels?
I'm that guy who finds ways *not* to do things..
Old 11th June 2012, 09:48 PM   #828
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I wish you would write the voltage when you post a schematic, and not just B+
Old 12th June 2012, 05:01 AM   #829
I never compared. I just used what would fit in the low chassis I had. Since the chokes were 40mA I had to use 2.
Old 12th June 2012, 06:10 AM   #830
Stixx is offline Stixx  Germany
Stixx's Avatar
delete
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
