#801 |
Builders got about 15dB. Nelson appears to sum top andbottomportion of PP Fe. Dont know why, and if you did the same to F5, you woyld find they are back to being similar again, in this respect. Iam more than happy to talkabout it in the BA3 thread.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#802 |
diyAudio Moderator Emeritus
The pics.
#803 |
We want to see the goods. Where is the pic of the top? Have you listened on main system more?
#804 |
ok, lets stick to that
![]() maybe because in BA-3 FE the signal is summed into one, like a preamp (F5 jfets are not) |
#805 |
#806 | ||
Go to the BA3 thread. Look up Generg. He specifically addresses the issue after building his. You are probably right and I am wrong. What you say makes sense. Shows my ignorance. I concede. Quote:
Bas, On my end, it is saying the video is private.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! Last edited by buzzforb; 10th June 2012 at 10:31 PM. |
#807 |
#808 | |
#809 |
Basman,
WRT the noise you're experiencing... could it be your smallish choke is hitting saturation? Cuz your first cap is only 2uF (from memory) the PS behaves like a choke-in filter. Loading thoose 150uF pulls lots of current... Perhaps you can experiment with a resistor of equal resistance in parallel with the choke to see what happen at half the power? Or replace it altogether
jaap |
#810 |
Discoman,
The choke is per channel. So about half of it's current is drawn. Should be ok? Btw the noise is actually not so bad. It sounds like white noise. Soft white noise...Not audible from my listening spot. Still. Not something I expected. Last edited by Bas Horneman; 11th June 2012 at 07:00 PM. |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
