6V6 line preamp - Page 79 - diyAudio
Old 9th June 2012, 09:49 PM   #781
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its low gain and is in need of every bit of oomph in the bass. DC and low Zo helps it, full DC path. IMHO of course. Having heard the F5 with DCB1, 6V6 as buffer, on my 95dB speakers they are closer in musical weight. F5 needs 12dB+ line gain and 95dB+ 8 Ohm flattish Z speakers to start partying, IMHO again. ~ 50W single output pair Andrej's SSA goes ''bigger'' easier on lazy speakers but its not a finished simple form DC steady kit yet. Apples to oranges VS F5. DCB1 was firmer VS #26 also on Baby Huey with Hashimoto OPT in Vgeorge's Lynn Olson's Beyond The Ariel line of thought 100dB 4 way system (90Hz up, subs active 300W). But #26 had a golden like harmonic hue (was not there in source) very beguiling without pushing back clarity. Still a bit shallower even with line level XLR OPT and autoformer pot. No DC path again, bass & midbass love straight paths it seems.
Old 9th June 2012, 09:52 PM   #782
buzzforb's Avatar
Hows that for opinion!
...Shape the sound , Man!
Old 9th June 2012, 09:56 PM   #783
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
nope, those are true facts
Old 9th June 2012, 09:58 PM   #784
Salas's Avatar
Thought I could give you a wider subjective frame to perplex you more.
Old 9th June 2012, 10:00 PM   #785
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
buzz what output stage are you using with your ba3 frontend?
I'm that guy who finds ways *not* to do things..
Old 9th June 2012, 10:01 PM   #786
buzzforb's Avatar
It appears i have to retract my apparent affection for the 6V6 preamp. I just dont know amymore
Mekanixz, it is standard BA3.
Old 9th June 2012, 10:34 PM   #787
It appears i have to retract ........
no need to do that, just state your facts, and everything will be fine
still dont understand why BA-3 works better with 6V6 than the F5
I really thought it would be the other way round, due to the known F5 lowish gain
some say they miss the 'grunt'
but I guess it also relates to your speakers, and listening 'habbits', music, etc etc
Old 9th June 2012, 10:38 PM   #788
diyAudio Moderator Emeritus
Bas Horneman's Avatar
nope
close pics and exact sch , please
First sch. Tomorrow pics.
C1 at the moment. 4 * K42Y-2 caps. Each 0,047uF. 2 Wired in one direction. 2 In the other.
Old 9th June 2012, 10:41 PM   #789
wasnt there a buffer version with cathode output ?
Old 9th June 2012, 10:44 PM   #790
Wasnt there a version with cathode output ?
Yes.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
