6V6 line preamp
6V6 line preamp
Old 8th June 2012, 10:42 AM   #741
SGregory is offline SGregory  United States
I found, like Buzz, that active regulation is the next level. Not required for really good sound however. When it comes to the heaters, I found that simple AC is best.
Furthermore, another tweek that I am on the fence with is using a ccs as the anode load vs. a resistor. I am currently using a CCS and have been for many months. Others swear by the simple resistor.
Stiff power supply, I am not sure, however, I used the parts I had which turned into a massive looking thing. IMHO, I don't think they hurt but not required provided channel seperation can be maintained.
These are just my opinions. As usual measurements don't show significant difference.
Living Life Doing the Waltz in 4/4 meter.
Old 8th June 2012, 11:22 AM   #742
buzzforb is offline buzzforb  United States
buzzforb's Avatar
At the risk of being stoned, the only thing I have not liked is the tube rectifier. As I said earlier, I haev not touched it since finishing it, but when i added the Winged C 5u4g, i got something i dont quite like. NOt as clean as the SS. I would argue it added something negative vs something positive. Probelm is, I threwit together, so it could be layout related. I also changed from CRC to CLC. Too many variables. I got a big matching thing to go through and all will be redone. I am going to layout the entire internals on a pcb for neatness, i know heresy, and then set the psu up in such a way that I can switch from SS to tube rectification. I like Bas' idea of tube after SS for slow ramp of B+. Will try it all. Main point....its worth it. Makes me want to try other big tube pre's. Got some of the Russian tubes Wavebourn recommended earlier in the thread as well.
PS I love tubes as Pre's with SS as power amps, FWIW.
...Shape the sound , Man!
Old 8th June 2012, 11:41 AM   #743
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I'll probably be stoned by the objectivists who maintain that different brands of rectifiers won't alter the sound. But the Russian 5U4G's aren't exactly the pinnacle of rectification. I found them in my amps to make the amps sound bright. Hence I've never used that rectifier ever again except for startup tests.
Its russian cousin 5AR4 is better already. The NOS 5R4 potato mashers is what I use most, since they can be bought for reasonable prices. Though I realize there must be better. They are perhaps not the best when it comes to bass and dynamics.
Though it would be cool to have a real Mullard GZ34/7. That is simply for people with a lot of money and no diy skills. The so called damper diodes are probably even better. I say probably because I have never compared them side by side.
If you can see the speaker cone move...it's not hifi.
Old 8th June 2012, 11:51 AM   #744
buzzforb's Avatar
Distorted birght is how i would describe it. I can see them adding "detail" to some speakers that fall of up high and perhaps that s their attraction, but i dont need assistance there, just honest reproduction. Is nt the tube you are using sfter SS, a dmaper diode?
Old 8th June 2012, 12:06 PM   #745
Yep. The 6AX4 is a damper tube. Able to supply 165mA constantly.
Old 8th June 2012, 12:10 PM   #746
buzzforb's Avatar
BAs, do you have a scehamtic of the SS/damper alyout?
Old 8th June 2012, 12:43 PM   #747
Sure. It might be worth your while to still add a RRSF (Reverse recovery spike filter).
Old 8th June 2012, 02:20 PM   #748
buzzforb's Avatar
Beyond my knowledge base. Tubes are very new to me.
Old 8th June 2012, 02:32 PM   #749
Here is Voltsecond's version.
Old 8th June 2012, 02:36 PM   #750
Proponents of solid state rectification use this to tame the recovery spike of the rectifiers. This recovery spike excites the secondaries of the transformer. And couples into all other windings.
The RRSF is said to ameliorate solid state rectification. The advantages of ss (cheap/works for ever/no separate heater) remain ofcourse. And the disadvantage is removed (noise).
Since I'll have none of the switching noise because of the damper tube. I'll still have to solve the reverse recovery spike. So I'll implement it as well. But I was lazy last night. I'll probably get to it after a couple of listening sessions.
JC Morrison even uses big *** chokes in his Silbatone amps!!!
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright ©1999-2017 diyAudio
