Old 6th June 2012, 11:25 PM   #731
nicoch58's Avatar
Bas thanks !
Sic58
Old 7th June 2012, 09:59 AM   #732
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Prego.
Old 7th June 2012, 10:05 AM   #733
BAs. Here is mine.
Awesome build!
Old 7th June 2012, 11:17 PM   #734
Click the image to open in full size.Made some progress.
Rectification is solid state followed by a single 6AX4. Not enough space for another 5v transformer. And I reckoned the 6X5 would be a little fragile.
Old 7th June 2012, 11:31 PM   #735
buzzforb's Avatar
NICe! PIO in there. Got to get some of those.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 7th June 2012, 11:41 PM   #736
The best thing about them? I got them as a gift from member dvb-projekt!!!
Old 8th June 2012, 02:01 AM   #737
Okay, you guys have motivated me to get mine in a case. Bas and Buzz, forgive me in advance as I am going to steal bits of your chassis design to make mine.
Here it is now, and has been for almost 6 mos. Since it is staying it is time to make it safe with a decent WAF. I will keep you posted. Looking forward to getting in the woodshop.
Living Life Doing the Waltz in 4/4 meter.
Old 8th June 2012, 07:05 AM   #738
disco is offline disco  Netherlands
disco's Avatar
How much of the circuit's quality is depending on the stiffness of the power supply? I mean, is the active regulation (and fixed heater current) obligatory for good operation?
NB Bas, are you gluing in the transformers and capacitors?
jaap
Old 8th June 2012, 08:33 AM   #739
Glue with silicon kit. And a screw or 2 to keep it in place while the silicon is drying.
Old 8th June 2012, 08:35 AM   #740
The active regulation probably takes it to the next level. But I'm starting of my listening sessions without the regulators. But Salas's SSHV2 are almost finished. And I will try them after a month of so of listening to the regular psu.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
