6V6 line preamp - Page 72 - diyAudio
Old 6th June 2012, 11:32 AM   #711
buzzforb's Avatar
Bas,
You got to try it with Salas HV shunt supply. Makes a difference. Go all out. It is worth it. I even sparng for some RCA NOS Blackplate Military grade tubes. ONce again, well worth it. Would not have done so if i was not impressed enought to make it a permanent fixture.
...Shape the sound , Man!
Old 6th June 2012, 12:16 PM   #712
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Will do. I have sshv1 and 2's...
Old 6th June 2012, 09:40 PM   #713
HI Bas link on Ikea stuff ?
Old 6th June 2012, 10:14 PM   #714
Accessori interni per cucine
FÖRHÖJA Portaposate - IKEA
Only the piccoli uno is there. There is supposed to be a larger one as well.
FÖRHÖJA Bestekbak - 22x25 cm - IKEA
Old 6th June 2012, 10:45 PM   #715
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its even structurally reinforced with effective braces. Nice one.
Old 6th June 2012, 10:48 PM   #716
Salas's Avatar
Would be happy with some O-Rings for 6V6's bases, since they are vibration sensitive when in 15dB gain mode. Especially the cylindrical anode NOS ones except RCA which is noticeably better for that, but all get affected a bit.
Old 6th June 2012, 10:51 PM   #717
I'm getting the new Tungsol 6v6. Will make a plan if microphony is a problem.
Old 6th June 2012, 10:56 PM   #718
buzzforb's Avatar
The Tungsol will get you 85% of the way, maybe more. We all know that most of the money is spent in tweakers corner. Salas, Do you think heat will be a problem in thats structured cell setup. I really like the ease of setup. Jsut cant beat it for a quick case. Looks good to boot with tennon joinery
Old 6th June 2012, 11:02 PM   #719
Salas's Avatar
Well, each one bottle runs at 5W, I will have to go aim my IR gun at their bases, because I forgot how many C I had found on them. I will report in 5 mins so you will be able to judge if it can darken that wood and its finish around the bases collars.
Old 6th June 2012, 11:03 PM   #720
I've already done some searching. Turns out. Apart from other 6V6's there is 6F6G and others. Looks like a tweakers dream.
I'm also considering the Lundahl LL1660/25mA as output instead of caps? Has anyone tried that? But first I'm building it as specced by Salas.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright ©1999-2017 diyAudio
