6V6 line preamp
6V6 line preamp
Old 10th April 2012, 11:49 PM   #661
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Originally Posted by buzzforb View Post
Still bright oddly enough.
A Zen cosmic filament light as sent by ZMod or just running it over 5VAC?
Old 10th April 2012, 11:59 PM   #662
Salas's Avatar
6V6 line preamp
Bypass with pios for a more err...mundane tone maybe.
Old 11th April 2012, 12:15 AM   #663
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
6V6 line preamp
Salas .....
do not tell him anything , without sch drawn
we had already enough complication for few days
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th April 2012, 12:26 AM   #664
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I checked and it stays under 5V Much more likely that tube hitting wood mounting causing nasty vibrations. Didn't have right tube socket(pcb only with no mounting bracket) so glued to wood top. Got new one coming
PIO is first cap in PSU.
Truthfully, I am going to give it some time to see if caps "run in" any. Listening to Allison Kraus, you can hear it in her voice. Same with Mark Knopfler on Ragpicker's dream. I did have 4.7uF Obbligato PIO bypassed with Wima MKP10 .47uF. Took it out. Problem is, I have changed too many variables. Also, my FR units would be called bright by some. 6v6 was big step in right direction, driving BA3, but tube rectifier is not what I expected. I have no doubt it is me, but need time to figure it out. I'll be sure to ask questions or send personal PM's when necessary
...Shape the sound , Man!
Old 11th April 2012, 12:34 AM   #665
Zen Mod's Avatar
6V6 line preamp
too many posts on too many pages
do you have somewhere proper sch or at least block sch of actual preamp ?
I presume you have shunt reg there ;
if yes , it is hardly that you'll hear too much of difference between solid state and tube rect. , especially if you're using choke in PSU
nevertheless , choke input PSU could be best , in case you have enough ooomphs in xformer secondary
btw - that resistor going from rect. cathode to first pio ; desolder it , put wire bridge instead ;
divide resistor in two , halved in value . and put one of them in each anode of rectifier
decrease their value if needed , to have proper voltage on first pio
that way tube rectifier will work more relaxed
Old 11th April 2012, 12:35 AM   #666
Salas's Avatar
6V6 line preamp
Last cap is the more showy, try bypass or double up there after you let it bbq for a while first in chance it mellows out a bit. Ask Zen about bbq on stones for good tones. He is PM friendly.
Old 11th April 2012, 12:41 AM   #667
Salas's Avatar
6V6 line preamp
That gato ain't papery. Is a film oily gato, puss in poly boots.
Old 11th April 2012, 12:41 AM   #668
Zen Mod's Avatar
6V6 line preamp
Originally Posted by Salas View Post
...... He is PM friendly.
only if you are sending me Olive Oil in PM
Old 11th April 2012, 12:42 AM   #669
buzzforb's Avatar
divide resistor in two halved in value and put them in each anode of rectifier
The 6V6 is built as Salas spec'd it with dual SSHV2 and CCS filament voltage. Sounded angelic. Decided to change PSU, to CLC over CRC, and at same time add, 5U4G Winged "c" blackplate. Too many variables, I know, but it has not improved the circuit. As I said, probably sloppy me and my implementation. Do have parallel 330R resistors before first cap, will break up as you said. Will pursue more slowly now. BTW, you have multiple PM's
Old 11th April 2012, 12:42 AM   #670
Zen Mod's Avatar
6V6 line preamp
yeah
motor run in audiophool disguise
edit - better to use proper 50uF Icar (Eu side of big splash) or GE (Yank side)
cheaper and bigger
edit edit - I'm not seeing any PM
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2017 diyAudio
