6V6 line preamp
6V6 line preamp
Old 10th April 2012, 12:58 AM   #641
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Do this and you should have no hum. Your 6.3V secondaries aren't strong enough and you parallel those I suppose.
Old 10th April 2012, 12:59 AM   #642
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Yup.
...Shape the sound , Man!
Old 10th April 2012, 12:59 AM   #643
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
6V6 line preamp
buzz
one 6V3 winding is directly connected across 5U4's 5V heater !
does just one 6V3 winding have enough current for heating 5U4?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th April 2012, 01:01 AM   #644
buzzforb's Avatar
Just to be sure, you are saying wire the two 330V secondaries in series , not parallel, and common point between two taken to ground.
Old 10th April 2012, 01:03 AM   #645
buzzforb's Avatar
Originally Posted by Zen Mod View Post
buzz
I have both 6.3V secondaries in parallel to rectifier. Should be 6A. Antek generally under spec's their trafos, so even one should do, rated at 3A; although working too hard i would imagine.
Old 10th April 2012, 01:04 AM   #646
Zen Mod's Avatar
6V6 line preamp
I just saw what Salas wrote about weak windings ........
you canconnect them in parallel , but!! securing that each 6V3 winding have own fixed resistor ;
so determine those resistors by trial and correct , going from higher value , that way that they're paralleled at tube heater
than take your Ub from whatever side of rectifier tube's cathode , as Salas posted
Old 10th April 2012, 01:06 AM   #647
Salas's Avatar
6V6 line preamp
Use one 3A 6.3VAC secondary with your CL60 is another way. Should suffice. If it goes a little under 5VAC is better for the 5U4G's lifespan.
Old 10th April 2012, 01:07 AM   #648
buzzforb's Avatar
THe resistors before parallel point being an attempt to balance draw and reduce hum, as hum is essentially a difference or imbalance in voltage?
Old 10th April 2012, 01:08 AM   #649
buzzforb's Avatar
You guys rock!
Old 10th April 2012, 01:14 AM   #650
Zen Mod's Avatar
6V6 line preamp
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
