| diyAudio Sponsor | ||
#481 |
Assembly begins!
#482 |
#483 |
diyAudio Chief Moderator
I hope those Sylvanias will prove amongst the least microphonic then and you stay loctal.
#484 |
I have a pair of Philips 6V6GT also so I can compare them with the Sylvania's
#485 |
Asked in SSHV thread, but thought i would ask here too.
"Stupid question, I know. But to do final adjustements with tube attached, does the filament voltage also need to be attached. I would assume that without it, the tube is non operable." I just wanted to quote myself. |
#486 |
that question is stupid , if you know answer
![]() if you don't , then it's not stupid so - yes - tube needs hot heater for proper operation
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#487 |
First tube and voltage in hundreds, so no question is stupid. Thanks Zen
#488 |
yadayada
ya know .... serve & protect ....
#489 |
Any reason why my filament voltage want go above 2V? I get 15V unloaded. I have 2.7 10W instead of parallel 15R and 3.3R. I calculated that this should be correct. Secondary is capable of 3A. What going on?
Pin 2&7 for HV, correct. |
#490 |
The Vh will go nominal when the Ih will be nominal through the filament (allowing for +/- tolerance). Check the voltage drop across your LM317T CCS resistor. Does it compute to nominal Ih?
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
| Page generated in 0.09685 seconds (75.44% PHP - 24.56% MySQL) with 11 queries |
