6V6 line preamp
6V6 line preamp
Old 11th January 2012, 01:22 PM   #401
Bonsai is offline Bonsai  Europe
Originally Posted by bequerel View Post
James transformers are beautifully made, and very nice quality at an acceptable price, but probably not in the Hashimoto or Magnequest league.
(If you are on a very low budget, Daburu is usually even cheapter than James.)
Thanks for the feedback
Old 11th January 2012, 01:24 PM   #402
massimo is offline massimo  Italy
Originally Posted by buzzforb View Post
RTFM applies here, I believe.
RTFM applies always, I'm afraid!
Old 11th January 2012, 01:33 PM   #403
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by massimo View Post
Ok, but how many (roughly)? 2? 4? 6? or....
P.S. If I'm not wrong Coleman's Regs work more or les on the same principle (CCS)
It can regulate down to around 2,5 V headroom but taking ripple in consideration I would say you need about 5 V headroom. Then your fine with just a big electrolyt before the regulator.
Staffan
Old 11th January 2012, 02:16 PM   #404
6V6 line preamp
Needing 6,3 V regulated takes 6,3 plus up to 2V for rectifyer loss plus 5 for regulator. Divide that with 1.41 gives you around 9,5 on the loaded tranny. Salas choice of 10 was not a coincident.
Staffan
Old 11th January 2012, 02:18 PM   #405
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
6V6 line preamp
say 4 as minimum
Rod's reg is made as filament (cathode!! for DH tube ) sandwiched between CCS and cap multiplier
it's waste using it for indirectly heated tubes ,with absolutely no benefit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th January 2012, 10:29 PM   #406
buzzforb is offline buzzforb  United States
buzzforb's Avatar
What would be the minimum recommended prefilter? I didn't realize this would cost as much as the rest of the amp. Mouser has hammond choke @$34 and Panasonic 500V 220uF caps at $10 each. JJ caps at parts connexion are $14 for 500uF. Also, If in a seperate enclosure, do i put all this in the psu and umbilical to main box or put prefilter in main box with regultor? I am assuming regulator needs to be in main box.
Old 11th January 2012, 10:36 PM   #407
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
220uF 220R 220uF I would say as minimum cheap CRC (with solid state bridge). When planning a reg it suffices. If you can make it CLC it tends to sound better. But the choke should be a man at >100mA constant current. 5-10H. If you will put the fiter in another box, use a 10uF MKP or MKT very near the reg's input to ground for decoupling.
Old 11th January 2012, 11:43 PM   #408
buzzforb's Avatar
Hammond choke at mouser is 20H and 100mA. I looked at the Panasonic ED caps which are 450V 470uF. If this looks good, I will pull the trigger. I tried it all in Psud. Not a lot of difference using more or less capacitance on output, but i cant say i know what I am looking for. Its wierd, the filter with 200uF seems to reach regulated voltage faster than lower capacitance. This is just a result of greater charge time for larger cap, correct. Are you using seperate PSU and how is it arranged? tube rectifier recommendation or will any of the schematic list work equally? I think I read that 5U4G doesnt charge as quickly abd helps with v spikes, or is it current spikes?
Old 12th January 2012, 12:05 AM   #409
Salas's Avatar
6V6 line preamp
With tube rectifiers there is much smaller first cap max spec. Each one notes so in its datasheet. It doesn't work well beyond that max and it expires much sooner.
Old 12th January 2012, 12:09 AM   #410
buzzforb's Avatar
I assumed a 4.7uF Obbligato Film in Oil in the first cap position since it is what i have, I also simmed the PSU with it. I was speaking of the second cap. I can get BHc aerovox on the Bay, but it will mean waiting. Will probably jst go ahead and get the PANa's.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2017 diyAudio
