Old 10th January 2012, 10:30 AM   #391
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by buzzforb View Post
Salas,
tube or solid state rectification? Recommendations or does it matter.
I had used 5R4GY & 5AR4 mostly for it, never had it with SS. So no experience of pros and cons with this pre.
Old 10th January 2012, 10:33 AM   #392
buzzforb's Avatar
Choke loaded?
Old 10th January 2012, 10:36 AM   #393
stajo is offline stajo  Sweden
Choke loaded?
Is never wrong, if you got the voltage and amps for 340 B+. Salas used caps tho.
/Staffan
Old 10th January 2012, 10:40 AM   #394
Salas's Avatar
Choke loaded?
CLC it is.
Old 11th January 2012, 12:01 PM   #395
buzzforb's Avatar
Salas,
I have orderd the last of the parts with a few exceptions. I have cohsen to go solid state on the B+ simplty because i don't have enough secondaires on my trafo, 2-300 and 2-6.3. The question i have concerns the LM317 regulator. I have never seen it wired this way an don't know the actual operating conditions. Since there are no voltage setting resitors, is the voltage equalt to that after rectification? Is the current set by the 5W resistors? I only have 6.3 V taps on my secondary. These seemed ok seince the thube datasheet showed 6.3V and 45mA for filament. You seem to have it running at higher specs if i am figuring correctly. Sorry for the basic question.
Old 11th January 2012, 12:11 PM   #396
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
download datasheet of 317 and you'll see that's basic CCS arrangement
you need few volts more for headroom ( CCS needs few volts for proper operation)
can you add several turns of enameled wire , connected in series with existing filament winding ( toroid ? ) ?
I hope 45mA is typo ......... with one zero missing
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 11th January 2012, 12:17 PM   #397
buzzforb's Avatar
THanks ZenMaster. I took a quick glance at the formula at the top of the datasheet showing voltage regulation and went no further. RTFM applies here, I believe.
Old 11th January 2012, 12:19 PM   #398
You could also serial the 2 secondarys. Connection between the two 300 would be your zero for tube rectifying.Serial the two 6,3 gives 12,6 wich is good headroom for the LMs
Staffan
Old 11th January 2012, 12:30 PM   #399
buzzforb's Avatar
Thanks to all. It is funny how much pleasure i get out of figuring out something as simple as a 317 CCS regulator!
Old 11th January 2012, 01:21 PM   #400
massimo is offline massimo  Italy
Ok, but how many (roughly)? 2? 4? 6? or....
P.S. If I'm not wrong Coleman's Regs work more or les on the same principle (CCS)
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2013 diyAudio
