#371 |
Thanks for that - the original GE datasheet for 6V6 notes that any mounting position is fine. Couldn't confirm for 5AR4 though.
Also, on the note of the cathode bypass capacitor, I've seen several values used on the thread, ranging from 220uF to 1000uF in various schematics. Has the consensus been reached at 1000uF? Elna Silmic II is readily available in 1000uF @ 35V. |
#372 |
diyAudio Chief Moderator
Its a nice one, had used it also for long.
#373 |
How about the 1M Kiwame at the output? I was only able to find a 5W 1M Kiwame, but I see some of the schematics also used smaller values. Is that value critical?
#374 |
Down to 470K not critical.
#375 | |
Resistor: Mills Capacitor: Black Gate |
#376 | |
#377 |
#378 |
Any recommendations for a good line out transformer? I will need to drive quite a low load impedance (few k) so capacitive coupling is not the preferable output coupling option.
http://www.veiset.net/BO/BO26MAI07A.gif Last edited by Bonsai; 9th January 2012 at 10:26 PM. |
#379 |
#380 |
if you open a new thread with your power amps, I will move these post over
seems like 'wasted' here, once this thread returns to topic
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
