#341 |
#342 |
diyAudio Chief Moderator
Cool test preamp. Is it the gain version (common cathode) CCT? What make of tubes, and what heaters power scheme?
P.S. You already wrote AC for heaters, OK. |
#343 |
Yes, gain version. Were there a cathode follower to? Didnt see that. Tubes is old RCAs testing fair. Regular electrolytics as cathode resistor bypass, 1uF MKP output caps, resistors what I found around. Other then that, fairly as the schematic I found in this thread.
Heaters power scheme? Regular AC 2 lines 6,3 VAC from the trafo. It has 5 V to. From an old radio. Staffan |
#344 |
RCAs are great. Black anode? Yes there was a bootstrapped cathode follower also shown for those who want a buffer. Repeating for quick reference:
#345 |
Salas,
you ever tried Susy tube linestage? In the back of my mind, i am thinking that if this goes as well as expected, it might be cool to do dual mono version like john mcclaens balanced B1 or even simple Susy. |
#346 |
Susy, no. I have a single ended wired system anyway. So no opinion on that question.
#347 |
FWIW, musicians friend is having sale om matched TungSol 6V6 for $35.
#348 |
New from Saratov, or American NOS?
#349 |
Unsure. Jusr got the notice.
#350 |
Black anode. Cool, maybe I'll re-bread it to buffer while waiting for regulator stuff. Gonna tune and "compactisize" the filterlines to and work it out for two 340/360 lines, for with and without SSHV2. I have two old output trafos from old radios at about 11 H each that I think will take the current.
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
