6V6 line preamp
6V6 line preamp
Old 14th June 2018, 03:48 PM   #3371
Anchan is offline Anchan  United States
Originally Posted by Salas View Post
No if you also put a 10k-20k log pot after it
Without the pot, there are some issues?
Old 14th June 2018, 06:33 PM   #3372
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
There is very high input impedance in the buffer that will reflect to the primary if without any resistor from input (before cap) to ground. Maybe it can pick noises easier. But you can also define the input impedance of the buffer with just a resistor in the pot's place.
Old 14th June 2018, 10:38 PM   #3373
Ok, makes perfect sense. Thanks!
Old 16th June 2018, 03:58 PM   #3374
skrstic is offline skrstic  Serbia
50Hz hum. Vhat can I do?
SSHV is not plug in.
Old 17th June 2018, 02:57 AM   #3375
Salas's Avatar
6V6 line preamp
Another newer build? Is it the cathode follower? Are the heaters grounded to chassis?
Old 17th June 2018, 06:23 AM   #3376
Not a new. It's CF but in enclosute. Hum vas little less earlier but preasent. Heaters grounding is from left and righ to central tap.
Old 17th June 2018, 07:54 AM   #3377
haiqu is offline haiqu  Australia
haiqu's Avatar
Beam power tetrode used as a line preamp? Hmmm ...
[VK9VK] With great power comes great current squared times resistance.
I spent most of my money on fast cars, hot girls, hi-fi gear and booze. The rest I just wasted.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
