6V6 line preamp
6V6 line preamp
Old 4th January 2012, 05:42 AM   #311
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
6V6 line preamp
Originally Posted by Salas View Post
What type does this curve tracer screen refers to?
6P15P in triode mode. I used it as a driver in Pyramid-VII and Tower-V amps.
The Devil is not so terrible as his math model is!
Old 4th January 2012, 05:42 AM   #312
kevinkr's Avatar
6V6 line preamp
I won't ruin Anatoliy's fun, but you'll like the answer..
Edit: Wow, simultaneous post..
Do you think Salas should be interested in 4P1L as well?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th January 2012, 05:45 AM   #313
Wavebourn's Avatar
6V6 line preamp
I believe he is well aware about it. But it is directly heated tube, unlike 6V6.
Old 4th January 2012, 05:57 AM   #314
kevinkr's Avatar
6V6 line preamp
I've got some slated for a small SE power amp..
I also have 6P15P, these in addition to the 4P1L I seem to recollect were bought on your advice.. One of these days I will get around to doing something with them..
Old 4th January 2012, 06:03 AM   #315
Wavebourn's Avatar
6V6 line preamp
Did you buy also 6N16B, 6N17B, 6S17K, Gu-50?
Old 4th January 2012, 06:10 AM   #316
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
That is a great one in triode, maybe better than EL84 itself that its supposed to be the Russian alike, but has 3 times the gm of 6V6. Will give much gain for useful line pre with today sources I think.
Old 4th January 2012, 06:13 AM   #317
Wavebourn's Avatar
6V6 line preamp
It has denser screen grid. Russian EL84 is 6P14P. 9-pin version of 6V6 is 6P1P
Old 4th January 2012, 06:17 AM   #318
Salas's Avatar
6V6 line preamp
Similar though? Interchangeable?
Old 4th January 2012, 06:20 AM   #319
Wavebourn's Avatar
6V6 line preamp
Which one?
Old 4th January 2012, 06:21 AM   #320
kevinkr's Avatar
6V6 line preamp
IIRC the 6P15P is similar to the 6CW5/EL86, but I don't recollect the 6CW5 being quite that linear - although it has a lot of fans based on its sound quality.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
