6V6 line preamp - Page 30 - diyAudio
Old 3rd January 2012, 04:53 PM   #291
kevinkr's Avatar
Originally Posted by tinitus View Post
EL34 fore preamp ? that would be 'a first time, wouldnt it ?
It would work OK, might not sound as good as the triode connected 6V6 - not sure, interestingly enough the 2A3 sounds quite nice in line stage applications.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 3rd January 2012, 05:21 PM   #292
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It could, but the dissipation should be much higher than 6V6 class which is already nicely linear in triode. Fat older ST bottle (Coca Cola style) 6V6 tend to sound mellower and be more ringy in this application. In power amps the output transformer ratio extinguishes the voltage gain into current transformation so microphonic behavior its not noticeable.
Old 3rd January 2012, 05:24 PM   #293
massimo is offline massimo  Italy
...and what about the EL84? Close enough to the 6V6 and good sounding.
Old 3rd January 2012, 05:32 PM   #294
Salas's Avatar
Has been discussed in the thread's start. 6V6 was only the beam tetrode Yankee reply to the Eindhoven extra grid patent, they are same class different taste. At 5W dissipation in my preamp I would still argue pro American tubes bigger envelope in this class. 0.0048% THD+N in Gregory's CF and -120dB to -143dB 20Hz-20kHz noise floor in post #231 is not a particularly disappointing result anyway.
Old 3rd January 2012, 05:38 PM   #295
Certainly no complaints on my end. I concur with the characteristics between the coke bottle and straight glass. Found an old Delco 6V6GT in my tube box that checked out fine. Has a bit more in your face feel. May order a few Tungsol ST's for fun.
I do have a couple of the small tube mentioned earlier. May have to play with that in the next day or so.
Living Life Doing the Waltz in 4/4 meter.
Old 3rd January 2012, 05:40 PM   #296
Salas's Avatar
There was a Manley 300B preamp also I think.
Old 3rd January 2012, 05:41 PM   #297
Salas's Avatar
Scott:
Still on active cathode load in your follower?
Old 3rd January 2012, 05:54 PM   #298
For the time being. Work has me occupied for a bit. All I can do right now unfortunatley is listen ;-)
Now about the 300B. I have two Mesh Plates sitting on the shelf.
Old 3rd January 2012, 05:56 PM   #299
Salas's Avatar
Which one CCS you use? A resistor ought to give some more THD when you will test switch and a noticeably different sonic, maybe less ''monitor''.
Old 3rd January 2012, 06:18 PM   #300
Cascaded DN2425
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
