6V6 line preamp
diyAudio Chief Moderator
Joined 2002
AC heating owes to work best with the buffer version of course. I have seen the cleanest grass on FFT in all versions when with regulated DC heating nonetheless. AC heating harmonic noise can be helped with balancing resistors of grounded center in the secondary if necessary.
Reactions: 1 user
Salas,
Of course, you were right, 10k.
But, I made the mistake of Not stating in my post . . . that you have to use a bypass capacitor across the self bias resistor:
In that case we are talking about 5k rs (screen impedance).
That should be easy to verify by adding the bypass cap, and running LT Spice one more time.
That reminds me of Count Basie, he was recorded as saying: "One More Time". I am sorry, that is a bit obscure to many readers.
Happy Listening Everybody!
Reactions: 1 users
@Salas what's the point of 2.2uF at the output? Are you driving low Zin power amp or it's just the lowish plate resistor?
In the latter case I suspect it would work best with a good output transformer with 80-120H primary inductance and 4:1 ratio with bypass of cathode resistor. For example, the Lundahl LL1660 ALTQ is already finer in its standard 16 mA version but primary L could even better at 140-150H with air-gap for 108-10mA. This would also allow separation of ground loops between the preamp and power amp with great benefit for S/N ratio (basically leaving secondary floating and getting grounded in the power amp once connected).
If the Zin of the power amp is 50-100K or more the RC at the output could be modified with significantly lower C. ALL capacitors get worse when their value goes above 1uF, more or or less. The smaller the better!
Joined 2002
Hi, the point of 2.2uF is it can cover minimum phase turn coupling down to 10k-20k Zin amps. Which the CF and G3X versions can drive even better. They have 250Ω and 1kΩ Zout respectively. Of course lower (thus cheaper also) Cout values can do the job when for high Z input power amps. I originally used 0.68uF for example. In general I favor a -3dB high pass coupling point of 5Hz or less for minimum phase turn up to 100Hz.
A (cheap) tube like the 6CH6 might be better in this application with step-down transformer coupling. -3dB @5Hz should be easy with a LL1660 ALT Q gapped for 8 mA. Should be able to drive anything without CF's and without capacitors....
45,
Thanks!
You indicated one way to match a preamp's output tube plate impedance, rp, to a lower output impedance is a step-down transformer.
What you reminded me of is one way to match a power amplifier's output tube's plate impedance, rp, to a lower impedance load . . .
is a step down transformer. Ome traditional way for a tube power amplifier.
The OTL, Output Transformer Less amplifiers, are not intrinsically a good impedance match; only with global negative feedback can an OTL properly drive a low impedance.
