Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#2511 |
diyAudio Chief Moderator
#2512 |
Hi folks , a question about a hum noise in buffer circuit with a simple crc+ 2last separate rc for each channel. I'm no surprise for litle noise with this kind of supply, but the noise go down a lot at maximum volume without and song is very clear the change of level...
Could somebody light me about? Thanks a lot for any answer ... |
#2513 |
diyAudio Senior Member
Not sure I understand but are you certain you have the volume control wired up correctly? Ciao, ![]()
Frank |
#2514 |
I think Was right i Can control level simpy the noise when the pot is in position without attenuation go down somebody db at my (not only) ear
#2515 |
The pot needs its body grounded also. Revisit the grounding scheme.
#2516 |
The pot is an blue alpls, the cover is mainly in plastic i have to ground the upper side? I'll try this evening thanks a lot!
the sound it's very good! I'll try with SE EL34 and with a little T-amp and result was fantastic gain in deep, detail and "body" of sound..., I'm thinkng to separate in two cabinet pre and supply for give him in future the chance of better supply based on your circuit. |
#2517 |
The Alps face plate is metal. It usually grounds when mounted to a zero referenced chassis. When not like that, use a collar and a ground wire.
#2518 |
P.S. About the sound congratulations. It will be even better when you will finish with all the build details. Better PSU is always a plus also. Post us some pictures when done.
#2519 |
Salas,
Time to rebuild the 6v6 preamp and I had a couple of questions. If I wanted to have balanced out, would it be smarter to use a unity gain phase splitter like the one found in the impasse, or a transformer? Would a standard 600: 600 transformer work on the output or would it cause issue? Lastly, have you had a chance to listen to the Amtrans Carbon Film?
...Shape the sound , Man! |
#2520 |
Such Tx would load down the gain version's higher than 600R Zo. Better an active splitter, or step down 5k primary Tx instead of resistor anode load with balanced secondary. Given that your system gain allows 1:3 gain loss at the pre. Line noise will go down accordingly as microphony also nonetheless.
*No use of Amtrans yet. BTW they have given good feedback on it in the phono thread but they ultimately preferred the very low ppm foil and the non inductive ww very low ppm too. But in no power demanding locations. |
Thread | Thread Starter | Forum | Replies | Last Post |
Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
New To Site? | Need Help? |
