6V6 line preamp - Page 24 - diyAudio
Old 31st December 2011, 04:13 PM   #231
Default Further Improvements
An update. The pre now runs with better ground pattern, ceramic caps from heater to ground on the base, plus a SSLVS(ver1) modified for filament duty. Attached is the FFT measurment. Red being before and Blue being current. 1Vrms Input = 0dB.
Measurements are good, but this may be a case where too much good is bad. While it is fully enjoyable, I almost prefer the way it sounded before. The majority of the 60Hz bump is my monitor sitting right next to it.
Living Life Doing the Waltz in 4/4 meter.
Old 31st December 2011, 04:37 PM   #232
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by SGregory View Post
....... but this may be a case where too much good is bad. While it is fully enjoyable, I almost prefer the way it sounded before.
why the blue peak at 1khz
Old 31st December 2011, 04:39 PM   #233
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Maybe you would like to listen with just CCSing the heaters with the input part of SSLV1.
Your harmonic noise profile shows a major improvement non the less.
Old 31st December 2011, 04:39 PM   #234
Salas's Avatar
Test signal for seeing THD.
Old 31st December 2011, 04:46 PM   #235
Salas is correct 1Vrms 1kHz test tone. Can see and measure THD with it.
I think I will take out the CCS as the cathode load first. The play with the heater.
Old 31st December 2011, 04:51 PM   #236
Salas's Avatar
Me I use a resistor after several circuits as load. Maybe you will like it too. Curious to know your inclination after you test.
Old 31st December 2011, 05:27 PM   #237
kevinkr's Avatar
That is the fundamental in the FFT measurement.. To the right are the harmonics of the fundamental, and to the left is the residual LF noise..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st January 2012, 06:58 PM   #238
Originally Posted by Salas View Post
Did anybody build or listen to a 6V6 triode connected line preamp? I think it may be interesting to build one since I have some NOS. Maybe SRPP.
I've seen it in the line stage of a tube comp I use.
but the whole thing is p-p line stage.
Old 1st January 2012, 07:36 PM   #239
Salas's Avatar
Was it a pro sound compressor machine?
Old 1st January 2012, 08:09 PM   #240
buzzforb's Avatar
Salas,
I have been poking around your threads and this one seems the most interesting or maybe the shortest, I don't know which. THat being said, anybody who listens to Sytem of a Down and owns tube gear, knows something, so want to build this and wasnt sure if this was the final schematic. I know you tried CCS instead of resistors but droppped because of gain and sound issues. Let me know so i can get building! First tube amp
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
