If the filament supply has 1.2A per tube capability there is opportunity to drop in test the lower voltage higher Gm spec 6W6GT.Save your money. ;-)
Its a dirt cheap NOS variety because not in demand due to weak voltage spec for the average guitar amp's plate and screen rails.
But the G3X pre doesn't use it like that. No problemo. It will probably give same THD figures but with halved output impedance.
Has much stronger heater to support its wide cathode. Originally used in TV sets to produce more current at lower rail voltages.
Expect 25-45V lower plate voltage and 5-10mA higher bias current when dropped in any existing Salas 6V6 preamp schematic.
Happened the same with expensive Melz 6N8S 1578 metal base hole round plate....
Interesting!
Thank you.FWIW, GE 6SN7GTA or GTB always my go-to tube. Full sound, nothing pushed out or recessed. Cheaper than new stock!
Salas I guess for NFB version without volume pot have I to not use 1K grid stopper resistor nor 1Meg leak resistor right? Of course have I to add the NFB, I ask because at the moment I will use for noDac line level amplification not line level preamp?
It's OK the attached schematic Salas?Only to be sure attached schematic, TIA Salas to check it.
- Tubes / Valves
- 6V6 line preamp
