6V6 line preamp
6V6 line preamp
Old 15th May 2013, 04:08 PM   #2321
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by Zen Mod View Post
time for beer
ook electronic
I would join you but the solder is hot
Cheers mate!
Old 15th May 2013, 04:28 PM   #2322
flatheadmurre is offline flatheadmurre  Sweden
Cheers mate!
A metaxa free build session .
Old 15th May 2013, 04:34 PM   #2323
6V6 line preamp
Usually worx
This is so hard to calculate in terms of unknown tube filament data so I think Ill just quick rig something and try a bunch.
Doing the Colvern plus extra series resistor parallell to 3,3 will be a close call in wattage.
Old 15th May 2013, 04:51 PM   #2324
Usually worx
The Colvern pots takes some abuse before they fail.
You can´t be dissipating more then a watt ?
Old 15th May 2013, 05:09 PM   #2325
6V6 line preamp
Say 12R pass 0,15 A which is not impossible if a tube draws 0,5 or some more even. 0,15 times 6,3 is 0,95 W so I SHOULD be within margins but its close.
Thing is, we dont really know how each and every tube acts when CSS fed. All I know thay acted very differently. I start with ZMs circuit and collect some data.
Old 15th May 2013, 05:17 PM   #2326
6V6 line preamp
Almost there
Freakin smallfingerjob
Anyways its homework and kiddo g'night story story tonight so we'll see
Old 15th May 2013, 06:21 PM   #2327
If you burn the Colverns i can supply the bigbrother.
They´re in the 3W range.
Next size bigger won´t fit the box .
Old 15th May 2013, 06:21 PM   #2328
6V6 line preamp
Changed my mind and built me an electric spaceinvader insect instead
Old 16th May 2013, 05:27 PM   #2329
6V6 line preamp
Hello insect lovers
The bug is now up and running and I have been running some samples. The schema is ZMs except for 10R pots and 18R series (R3).
I first ran it on 13R5 dummies and got between
5,82-5,93 and 5,84-5,95 volts (ch 1 and 2) by min/max on pot.
Then I dropped in a pair of RCA clearglass
5,86-6,09 and 5,98-6,14
RCA Black Anodes
5,43-5,61 and 5,51-5,68
Philips
6,01-6,23 and 5,71-5,91
Russian 6P6S
6,12-6,32 and 5,90-6,08
Well, what do we get out of that. At least I would like to be able to run different tubes in the same amp without having to open it and solder, so if running CSS on filaments I definately need a variable one.
Second I need a wider variation span. Almost 0,7 volts in difference between tubes is (only those few tested yet) is going to affect the sound to much for being acceptable for me.
The way to go might be to drop R2. That will put more current over the pot but make it more variable in current (and voltage).
Any suggestions/comments before I tear things apart?
Old 16th May 2013, 05:49 PM   #2330
You can raise the value of R2 and lower the value of R3.
That vill give you a wider set span.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
