6V6 line preamp
Joined 2009
diyAudio Chief Moderator
Joined 2002
SSHV2 working hard to tame the high ripple coming from PSU, can't increase the resistor value between the CRC of PSU because I need each volt available, will do with the new transformer.
Does good work. What the Brymen shows if you keep it connected to B+ but you power down the PSU? To see if its mainly general noise the test leads pick.
