6V6 line preamp - Page 227 - diyAudio
Old 14th May 2013, 12:29 AM   #2261
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Buzz..yes a 6ax4 after ss rectifiers for slow startup and "hiding" ss rectifier noise. I've added a snubber and chokes to "handle" the reverse recovery spike.
Old 14th May 2013, 12:30 AM   #2262
buzzforb's Avatar
Mind posting final version. I am ashamed to admit i liked the SS rectification version best, but blame this partially, at least(or completely), on my own ignorance. I wil have to give it a shot, but would like to have your circuit as well. If nothing else, seems clever.
...Shape the sound , Man!
Old 14th May 2013, 01:46 AM   #2263
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Bas Horneman View Post
By the way as we speak I'm exporting a dxf for a friend to cnc a plate for the Salas 6v6. (He just completed a diy cnc machine) So I'm curious to see how well it will turn out...Smallest bit he has is 2mm..hence the font and thickness. Still it should look nice.
Cool, like special numberplate car cool kinda.
Old 14th May 2013, 01:53 AM   #2264
Salas's Avatar
Hey Salas,
Still very much enjoying the Salas 6v6 pre! I find it hard to imagine anything being better. Still have not added the SSHV2's. I just have so little motivation for adding something to a project that works so well.
Bas
If it ain't broken don't fix it they say...
Still do publish your B+ PSU config and your heaters PSU config when able since there are experiments going on here and guys would love more options that work well I think.
Old 14th May 2013, 08:37 AM   #2265
stajo is online now stajo  Sweden
So how do I make a variable filament CSS best? One way would be to buy an expensive 2-3 W wirewound pot per channel and parallell with a 3 R ish resistor. Can anyone think of a better way?
http://www.onsemi.com/pub_link/Collateral/LM350-D.PDF
Old 14th May 2013, 08:46 AM   #2266
This is what I use. Simple but it works. (Plus I had the pcb's lying around doing nothing) I have the current source after the voltage source. But really some dc followed by a current source is good enough.
The pcbs can still be ordered if you don't want to do it p2p.
Scroll to LM317 PCB
A simple General Purpose PCB for Voltage and Current Sources
Or I'm sure there are cheaper alternatives on ebay.
Old 14th May 2013, 08:50 AM   #2267
Just check the app notes in that publication .
You can use a fixed sence resistor and a smaller pot for the setting.
Old 14th May 2013, 08:54 AM   #2268
Thanks Bas. Doede makes nice stuff, I like him. How do I calculate the wattage needed on the CSS pot? I tried to figure it out the other day but something interupted me.
Old 14th May 2013, 08:56 AM   #2269
You say fig 22?
Old 14th May 2013, 08:58 AM   #2270
You know the current going thrue.
Ohms law will tell you the rest.
Then multiply for a good safety margin.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright 1999-2017 diyAudio
