6V6 line preamp - Page 225 - diyAudio
Old 13th May 2013, 09:18 PM   #2241
6L6 is offline 6L6  United States
6L6's Avatar
Because between the different manufacturers there are many differences in the physical construction and materials used to arrive at (theoretically) the same electrical performance. And tubes wear out with use.
Also, nobody could measure back then like you can today... When those tubes were designed, the best research lab in the world didn't have access to the information you can get off your basic digital scope.
Old 13th May 2013, 09:21 PM   #2242
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
filament starving is for sissies
same as in case when using CCS heating for voltage oriented filaments , where you need to fine tune CCS observing voltage - for each tube separately - you also need to fine tune starving filament voltage not for every brand , but even for every batch of tubes in same brand
so - every old toobster will tell ya - leave it kiddoe - that hassle is nothing else than trouble - feed them as intended , and then you'll have expected behavior across entire
life span
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th May 2013, 09:32 PM   #2243
stajo is offline stajo  Sweden
That doesnt really explain the differences in frequencys to me. My wild guess is that I'm looking at a combination of filament interference and microphony planting from the mains tranny. Maybe. Wild guess, but can be tested.
life span
Old toob guy. Those fellows are intended for stuff that cant reproduce any 50 Hz and also as noice cancelling push pull output toobies configs. Then 6,3 AC is fine, even as it would have been a DHT. But we're in a different area now. Suggestions?
Old 13th May 2013, 09:43 PM   #2244
Nice 'scope, by the way...
Yes, Salas recommended just this one
Old 13th May 2013, 09:45 PM   #2245
Zen Mod's Avatar
clarify "those fellows"
too many threads in same time , too many posts ........ and I couldn't cope with all mistakes you made in measurements ( taking in account that you were in good company ) .
so - what's the problem now ?
Old 13th May 2013, 09:49 PM   #2246
iko is offline iko  Canada
iko's Avatar
be kind, rewind
Old 13th May 2013, 09:55 PM   #2247
Those fellows is the 6V6es. In a push pull output tube config its ok with several voltages of ripple and it cancels out in the OPT. In an SE preamp config millivolts apperantly makes differences to the result.
I am aware of that this is not their intended use, as I am of my faulty measures (I'm here to learn) but I really think this is a perfect example of learning to both tackle the problems and use the tools to analyze it.
If you dont agree please say so.
Look at the last 3 pics. They are taken with the same config, same environment just 3 different fellows. Explain the differences.
Old 13th May 2013, 10:02 PM   #2248
Zen Mod's Avatar
differences as result of different physical/electrical virtues of each toob
you still need to learn that each tube is result of hundreds of small very precise steps in manufacturing procedure and that there are hardly two same tubes in existence
but - as I wrote already - heating of tube is fundamental , most important condition for exploitation ; heat them as they intended to be heated , but in most proper way you can make it .
that way differences and spread of electrical characteristics will be minimized
CCS based heating is my choice ;
edit : few mishaps :
- I'm not here to not agree with learning , steepness of someone's learning curve etc. ...... just said that I didn't had time/energy to follow or even help , in case that I can and know how to help
- SE came historically before PP , so that was their intended use - especially in time when each uF was golden
Old 13th May 2013, 10:18 PM   #2249
Apperantly heating is one thing that needs to be investigated using those kinds of tubes for this intention. My first try was AC, second elevated AC and now some other ways.
Note that I have yet not listened to the different configs. I got stuck on measurment results and interpretation of the same.
I agree with both 6L6 and ZM that the tube charm is much about their individual charachteristics. Im still puzzled about the differences in curves frequencys tho. I think I can gather around 50-100 different 6V6es without going to far. A stupid thing would be to measure them all.
Hey ho, captain Ahab!
Old 13th May 2013, 10:25 PM   #2250
Zen Mod's Avatar
heater PSU must be rock solid stable , same as anode PSU
make first one in quality as you have second one , and result must be good ;
if you have trouble/disturbance from dirty (input) side of any PSU , only cure is to make it more remote , while keeping final reg elements near load ( tube itself)
choke in anode PSU is on dirty side - ringingzingingspitting creature , exactly intended to do these nasty things , instead of tube itself
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright 1999-2017 diyAudio
