6V6 line preamp
6V6 line preamp
Old 24th December 2011, 05:53 PM   #211
SGregory is offline SGregory  United States
Both will work. The blue washers are actually isolation grommets made for the purpose. Pretty cheap from grainger. The tubes are pretty well isolated. Have to hit the chassis pretty hard to get it to sound through the speakers.
Living Life Doing the Waltz in 4/4 meter.
Old 24th December 2011, 06:37 PM   #212
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
What 6V6 make are those in your pictures? Would be more microphonic if you had gain.
Old 24th December 2011, 06:58 PM   #213
Zenith lable. Not sure who manufactured it though.
Old 24th December 2011, 07:04 PM   #214
Cassiel is offline Cassiel  Libya
Sgregory I like your chassis (knobs too).
Salas isn't leaking any info out on the sub chassis. Top secret?
Old 24th December 2011, 07:07 PM   #215
Salas's Avatar
6V6 line preamp
Good ones. They might be Sylvania.
Old 24th December 2011, 07:10 PM   #216
Salas's Avatar
6V6 line preamp
What secret? From early in the thread I recommend some form of isolation. The less microphonic on steady chassis with the gain circuit was the new Tungsol from those I checked. In CF things are easier, and Scott's combination of CF and grommets won't create trouble with any make, even the most sensitive ST bottle ones.
Old 24th December 2011, 08:40 PM   #217
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I have nylon spacers and screws, can I use this black rubber ring (it's M3)?
Old 24th December 2011, 09:54 PM   #218
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
6V6 line preamp
They look very small and stiff.... try to get some soft rubber (like the one used in the SME3009 base plate fixing screw orings)... very soft.
RC
Old 24th December 2011, 10:01 PM   #219
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
6V6 line preamp
rubber grommets
mount tubes in a just big enough alu or copper plate
use rubber grommets in its chassis mounting holes
and in your main chassis, use grommets as well
mount a small piece of soft neoprene between plates, on mounting screw
use selflocking nut
mount your trafos with anti vibration rubbers too
screws should be very carefully 'adjusted'
it really makes a big difference on how much buzzing is transferred to the chassis
with a simple wooden stick(or stetoscope) you can easily hear how much
Old 25th December 2011, 10:21 AM   #220
Could you post a pic & where can I buy?
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
