6V6 line preamp
6V6 line preamp
Old 3rd May 2013, 08:35 PM   #2181
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Originally Posted by stajo View Post
D1 felt a little bullied to so it was replaced. Now its set happily to 260 Vout and 40 mA. I thank Metaxa for that one and wave to Zeus
5 star repair.
Old 3rd May 2013, 09:43 PM   #2182
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by Salas View Post
5 star repair.
Thank you. I went over for some more for helping me on the hum part also.
Old 11th May 2013, 09:45 AM   #2183
Salas's Avatar
6V6 line preamp
Any progress?
Old 11th May 2013, 10:00 AM   #2184
6V6 line preamp
With the Metaxa?
I'm rigging a new testbed for the 6V6. The barge grew out of the costume and it was to messy to know which factor gave what result. This one gonna be more up to modular approach. I'm thinking resistor AF, choke AF, resistor CF, choke CF, ability to go with or without SSHV etc. Its better to let it take some time and think it thru.
I've also been working some on the lab-bench. I noticed that the mV measuring got affected alot on how I held the probes, close to lamps, powercords etc. The bench is prepped with an isolated earthgrounded worktop and shielded AC etc. Ill post some when I have some results.
Old 11th May 2013, 10:10 AM   #2185
flatheadmurre is offline flatheadmurre  Sweden
With the Metaxa?
I'm rigging a new testbed for the 6V6. The barge grew out of the costume and it was to messy to know which factor gave what result. This one gonna be more up to mudular approach. I'm thinking resistor AF, choke AF, resistor CF, choke CF, ability to go with or without SSHV etc. Its better to let it take some time and think it thru.
Watch out for fluorescent bench lights !!
I have 2 over by bench and they are very measurable .
Building a separate Modular PSU gives you the benefit of using it for several different amps.
Old 11th May 2013, 10:16 AM   #2186
6V6 line preamp
Im thinking LED-lights, my halogen and also the scopes phosphor screen is easily measurable several decimeters away
Old 11th May 2013, 10:20 AM   #2187
Im lazy.....i just switch of the lights when its final measurement time .
Old 11th May 2013, 10:29 AM   #2188
Salas's Avatar
6V6 line preamp
Led lights better use a linear variable CCS because their usual PWM controllers are notorious for EMI.
Old 11th May 2013, 06:08 PM   #2189
6V6 line preamp
Im planning to take this down with another RC but is it safe to probe this with a 300 V / 400 V p-p scope or should i go for 10X?
Old 11th May 2013, 06:17 PM   #2190
Salas's Avatar
6V6 line preamp
Only with 10X probe setting at such HV. At 1X the probe can be much lower voltage spec than max quoted.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
