6V6 line preamp
6V6 line preamp
Old 29th April 2013, 08:33 PM   #2131
flatheadmurre is offline flatheadmurre  Sweden
Originally Posted by stajo View Post
So while Im puting for Ikos measure here, whats the local poll:
  1. fiddling filaments
  2. finding op points with B+
  3. decoupling chokes with a small zobel
What would be your first shot?
Setting the op point for the tube first.
Then you test some different tubes.
When you find a nice pair finetune the filaments.
Old 29th April 2013, 08:53 PM   #2132
iko is offline iko  Canada
iko's Avatar
6V6 line preamp
If you look at that picture, you will see that the spike at 50Hz is somewhere around -53dB. Let's assume this is relative to 0dB = 1V. To calculate how many volts -53dB is relative to 1V, you do 10^(-53/20) = 2.2mV. So, at 50hZ you have a ripple of about 2.2mV RMS = 2.2*sqrt(2)*2 = 6.22mV p-p. In Arta you can click the mouse on the spike and then use the lef-right arrow buttons on the keyboard to measure more precisely how many dB the spike is at its highest point. You can calculate like this the mV value of the ripple for the other harmonics as well, 100hZ, 150hZ, etc.
Suffice to say, you have more ripple than what you should have from the HV shunt regulator.
Old 29th April 2013, 10:12 PM   #2133
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
That FFT is on the audio output. It represents everything circuit in there. Why is it just rail ripple? Where was that ripple on the rail scope test? Hum is 50Hz ripple is 100Hz. But 100Hz is -90dB there. The spray of harmonic noise is too wide to be just ripple on the rail of a buffer at line level IMHO. If feeding B+ with just CRC I am not sure that the picture would change much. And such a test could easily eliminate rail related questions or point at the PSU side indeed so to move on investigating. I would bet more on oscillation of the reg on the choke than just ripple if it is coming from the rail. There is suspicious microphony reported also, I would investigate instability or loop area issues regarding the choke loading next.
Old 29th April 2013, 10:38 PM   #2134
Start with a basic resistor load and get the thing up and running properly first.
Chokes have a nasty habit of picking upp every unwanted signal there is.
Split the PSU from the amp getting rid of any AC near the amp.
I“ve got nice shielded industrķal power cables come and get them Stajo.
After that you can start investigating the amp for grounding and stability issues.
Now there“s so many factors involved .
Old 1st May 2013, 08:14 AM   #2135
stajo is offline stajo  Sweden
6V6 line preamp
Howdy. Its a kind of holliday here and I woke up early so what to do if not play around with new scope.
Yesterday I made a conversion of the choke loaded CF to a resistor loaded and listened and measured. (Pic 1) About the same looking Arta curves and a small hum plus audiable noice in speakers. I also tried to feed it directly from PSU filter, without SSHVs. Small differences regarding hum and noice but the 305 V on the anodes sure made music glare.
So, today I made some scoping on the power rails. First up is PSU filter on 13,5 k/channel dummyload. (Pic 2). Around 5 mV p-p (1,8 mV rms) which I think is to much for this config. Should be less if the measuring tools doesnt add something.
I made a sim in PSUD II that says 127 uV (Pic 3)
Then I set the SSHVs on same dummyload (Pic 4). 5 mV/div so now we are down to measuring tolerances but occasionally I also noticed small occational spikes on the scopescreen. Very hard to catch on camera but you can see a shadow on Pic 5. Then a view on the same with 2 mV/div (Pic 6).
For some reason SSHV V in looks more stable then when the bare PSU loads a resistor dummyload (pic 7).
After that I removed dummyload and plugged in the reconverted choke loaded audio circuit. Pic 8 on the anodes, 2 mV/div, and Pic 9 on cathodes.
I guess this takes a coffee, some reference measuring and more
Old 1st May 2013, 08:23 AM   #2136
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
6V6 line preamp
Cool
RC
Old 1st May 2013, 09:47 AM   #2137
Salas's Avatar
6V6 line preamp
Scoping at 2mV/div and not even filling a graticule. But from 4 to 8-9 you can understand there is some 50Hz introduced.
Old 1st May 2013, 01:57 PM   #2138
iko's Avatar
6V6 line preamp
Old 1st May 2013, 04:44 PM   #2139
6V6 line preamp
Filterchoke and transformer, EMI-experiment - YouTube
Old 3rd May 2013, 11:39 AM   #2140
Salas's Avatar
6V6 line preamp
So that was just filter chokes moving about or load chokes do it too? Lots of loop area and inductance makes fields easy to pick in general. Now if you will be able to create something like this out of just interference you are in for the next Nobel prize.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
