6V6 line preamp
6V6 line preamp
Old 20th April 2013, 01:13 PM   #1981
iko is offline iko  Canada
iko's Avatar
6V6 line preamp
Originally Posted by Salas View Post
Maybe bins too little. Here's what I got. Noise floor no test tone, response, 1kHz test tone.
edit: Now the correct files FFT
Hey Nick, did you make a note of what the preamp output voltage was for the last image?
Old 20th April 2013, 01:25 PM   #1982
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
About 300mVRMS not to push the audio card.
Old 20th April 2013, 01:27 PM   #1983
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by buzzforb View Post
First pic is loopback showing baseline at output level to measure 1W performance of amp. I have some 60hz niose, but it was do to crappy test rig.
As for 6V6, RCA blackplates is my choice as well. New Tungsol was very good( have matched quad for diff version), but Military grade RCA was worth money and this amp is worth the upgrade.
Its a beauty Mr Aldrin
Old 20th April 2013, 01:34 PM   #1984
Salas's Avatar
6V6 line preamp
Originally Posted by flatheadmurre View Post
LM317 works fine just adjust the current down until you get best performance.
I donīt remember exactly what i ended up with but itīs a bit lower then Salas original setup.
Depends on tubes brand and vintage also. CCSing for about 6.1V Vh is OK.
Old 21st April 2013, 09:07 AM   #1985
6V6 line preamp
Hi
I made me a filament CSS and tried some different resistorvalues and I can confirm that tube brands/age etc varies a lot in the filaments, I get values between 5,6-6,4 volts just by testing a handfull.
Seems like I need a VR pot in parallel to adjust. Maybe 3,3/18/VR100 or something.
Whats the deal on going for current adjust and why not a voltage one?
Old 21st April 2013, 09:29 AM   #1986
Salas's Avatar
6V6 line preamp
One thing is it lends soft start, the other thing is many find it subjectively preferable. Listen 4 your self and tell us your unbiased opinion.
Old 21st April 2013, 09:33 AM   #1987
6V6 line preamp
Yes it soft starts. I will rig it in with 2 tubes that goes slightly under 6,3 with a 3,3/18 in parallell.
If going with CSS it seems like I have first match the fixed resistors closely with DMM and then to make it adjustable
Old 21st April 2013, 09:53 AM   #1988
Salas's Avatar
6V6 line preamp
45sec to 1min with 6V6 to fully come up if I remember well. Yes, better have a means of slightly adjusting when having a stash of various makes and ages. Also to explore some starving sweet spot if you can feel any differences as Flathead does.
Old 21st April 2013, 10:18 AM   #1989
6V6 line preamp
It was impossible to tell since I still have this 100 Hz hum from hell that I dont seem to stumble over any solution to.
When I plug poweramp and pre in it starts with a gigantic hum that almost goes away when the 6V6es heats up and biases. But just almost.
The hum has some variations in character depending on how I feed the filaments. AC, DC, CSS, Voltage regulator, groundreferenced, lifted etc. But theres always a hum.
Maybe I'll throw the towel for now
Old 21st April 2013, 10:51 AM   #1990
Salas's Avatar
6V6 line preamp
Did you ground them heaters on a grounded chassis to psu return?
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
