6V6 line preamp - Page 176 - diyAudio
Old 13th April 2013, 05:15 PM   #1751
stajo is offline stajo  Sweden
Originally Posted by iko View Post
That looks bad! If it works well and your measurement method is good, it should look like a flat line. The attached image, an hv shunt reg of my own, at 500uV/div.
Well, I did a new PSU today.
I started to misstrust the other trafo and the AZ1 that closes up to its limits. Its a C-L-C followed by double R-C to each SSHV. They get 330 V in with about 85 mV ripple in, measured with both DMM and scope. SSHV out is 270 VDC and 76 VRMS. I have set current testpoints at 0,400 V for 40 mA.
Dummyload is 13k5 on each SSHV for 20 mA.
Are the SSHVs malfunctioning? Where shall I search?
Old 13th April 2013, 05:35 PM   #1752
Sinks get lukewarm, both CSS and shunts that are cooled by a 3 mm alu bottom plate
Old 13th April 2013, 05:38 PM   #1753
merlin el mago's Avatar
Staffan, How much ripple do you have with the new PSU?
Old 13th April 2013, 05:41 PM   #1754
As I say above: "They get 330 V in with about 85 mV ripple in, measured with both DMM and scope. SSHV out is 270 VDC and 76 VRMS."
But I ment ofc 76 mVRMS ripple out
Old 13th April 2013, 05:43 PM   #1755
So you have 9mV of ripple?
Old 13th April 2013, 05:44 PM   #1756
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
@ Stajo
Your #1746 post shows some undulation at about 0.32mS period. That is 3100HZ. Too high for being hum too low for being oscillation. In your #1752 picture I see long input cabling and some central GND node to it. Decouple the regs inputs right across their +IN/0V connector with small film caps and see if there is a problem with the raw DC part grounding scheme by trying alternatives.
Old 13th April 2013, 05:51 PM   #1757
Salas's Avatar
When driving one MegOhm input (or ten MegOhm for probe X10) from milliOhm source impedance you have a very receptive measurement loop to any kind of interference also. Use the short point ground coil instead of your GND crock. Remeasure. See if you get the same waves. See with and without remote sense. Although you use self made SSHV1 also that does not usually employ sense wires. Give us a clear account of the above so we can know the problems.
Old 13th April 2013, 06:03 PM   #1758
A 10 uF over each. Ripple in and out
Old 13th April 2013, 06:19 PM   #1759
I've got this crap to measure HV
And some pix on ripple out. First with noice unfiltered, second with a 10 kHz lowpass filtering
Old 13th April 2013, 06:20 PM   #1760
Salas's Avatar
Can it read HZ at mV level? Press the frequency button for input and output probing. Its suspiciously same level for in and out now, it could all be riding on the ground loop. Dress the long output cables in twisted pairs. Force pair, sense pair. Remeasure. Null the sense pair by jumpers at F0,S0 F+,S+. Remeasure.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
