6V6 line preamp - Page 175 - diyAudio
Old 12th April 2013, 09:50 AM   #1741
stajo is offline stajo  Sweden
Originally Posted by Salas View Post
We already see portion of audio band at -92dbV DUT/instrument combined noise floor (0dbV=1VRMS), -72dBV hum at 50Hz. You only got a 100Hz portion though. There is a menu that selects bandwidth, and there is a generator menu that selects test frequency.
That 50 Hz hum is actually audible with the ear in the cone. It was my meaning to work that away but I got hooked on measuring gear for some reason instead
I was a bit puzzled on how to work the groundrail best with the SSHVs a bit remote from the app. I first had filter ground rail to last lytic pack and then to SSHVs with thin copper. When I changed to thicker copper and wired filter-SSHV-last filterpack the groundhum more then halfed.
Old 12th April 2013, 01:16 PM   #1742
Had to do some new measures on spectral analysis mode. Now I really have to work away some gnd hum
Sweep, no sweep and with lower spectrumbins (1024) then default
Old 12th April 2013, 01:49 PM   #1743
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Seems its too low a frequency range for its sampling rate and deep memory to resolve well in high bin count. The noise floor looks like its Pico's own because the THD is buried in there. Only the hum is visible. Until learning ARTA and the like programs on a 24bit good audio card to exactly see, for now your build does not look high THD. Maybe if you push the input level but I doubt the Pico gen having any big output. If you will employ the Wavetek for that you will end up seeing its own sinewave THD mainly which is usually at 0.5% to 1% from lower to higher range for general use wide band function generators.
Old 12th April 2013, 01:55 PM   #1744
Salas's Avatar
P.S. Why it can't do a steady 1kHz test frequency?
Old 12th April 2013, 02:08 PM   #1745
Salas's Avatar
100kHz bandwidth selection could suit it better?
Old 12th April 2013, 02:22 PM   #1746
I will try later, have to solve this first.
SSHV out in app, SSHV out on dummyload. Same on both channels
Old 12th April 2013, 02:39 PM   #1747
iko is offline iko  Canada
iko's Avatar
That looks bad! If it works well and your measurement method is good, it should look like a flat line. The attached image, an hv shunt reg of my own, at 500uV/div.
Old 12th April 2013, 02:49 PM   #1748
Yes Im sailing again. I thougt Ive solved that but apperently it came back. Its ground relatez since its the same b4 and after SSHV. Now get kiddo
Old 12th April 2013, 02:57 PM   #1749
Salas's Avatar
It should look like in #1481 last picture when all is well. Sell the Pico on Ebay and get a real scope. Siberia scored a working Tek 2445 4X150MHZ for 200 UKP inc delivery the other week.
Old 12th April 2013, 03:21 PM   #1750
I guess I will do that some day. I baught the Pico when knowing almost nothing what to look for, which might still be the case for that matters:-)
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright 1999-2017 diyAudio
